I have tried to install Aggregate with Google App Engine, but it results
stucks when "Upload ODK Aggregate to Google AppEngine", in the dialog box
(Attached) nothing happens. Can you help me to identify the problem?
Hi Cesar,
This is most certainly a bug, but I can't reproduce it on my Windows 7 machine.
Can you file a bug report at
https://code.google.com/p/opendatakit/issues/list describing what
versions of ODK Aggregate installer, Windows, and Java of you are
using, and precisely the steps you took?
Then star the issue to get updates.
-- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.On Sun, Aug 31, 2014 at 4:34 PM, Cesar Renteria Marin renteriamarin@gmail.com wrote:
(Attached) nothing happens. Can you help me to identify the problem?--
Note also that you need java installed. See
On Mon, Sep 1, 2014 at 1:04 PM, Yaw Anokwa wrote:Hi Cesar,
machine.Can you file a bug report at
using, and precisely the steps you took?Then star the issue to get updates.
Thanks Yaw, surely, i'm filing the report. So, should I try in another OS?
About Java, yes, I read carefully instructions before I tried, and over and
over after this error.
El martes, 2 de septiembre de 2014 11:01:42 UTC-5, Mitch Sundt escribió: > > Note also that you need java installed. See > http://opendatakit.org/use/aggregate/ > > > On Mon, Sep 1, 2014 at 1:04 PM, Yaw Anokwa <yan...@nafundi.com > wrote: > >> Hi Cesar, >> >> This is most certainly a bug, but I can't reproduce it on my Windows 7 >> machine. >> >> Can you file a bug report at >> https://code.google.com/p/opendatakit/issues/list describing what >> versions of ODK Aggregate installer, Windows, and Java of you are >> using, and precisely the steps you took? >> >> Then star the issue to get updates. >> >> Yaw >> -- >> Need ODK services? http://nafundi.com provides form design, server >> setup, professional support, and software development for ODK. >> >> On Sun, Aug 31, 2014 at 4:34 PM, Cesar Renteria Marin <renter...@gmail.com > wrote: >> > I have tried to install Aggregate with Google App Engine, but it results >> > stucks when "Upload ODK Aggregate to Google AppEngine", in the dialog >> box >> > (Attached) nothing happens. Can you help me to identify the problem? >> > >> > -- >> > -- >> > Post: opend...@googlegroups.com >> > Unsubscribe: opendatakit...@googlegroups.com >> > Options: http://groups.google.com/group/opendatakit?hl=en >> > >> > --- >> > You received this message because you are subscribed to the Google >> Groups >> > "ODK Community" group. >> > To unsubscribe from this group and stop receiving emails from it, send >> an >> > email to opendatakit...@googlegroups.com . >> > For more options, visit https://groups.google.com/d/optout. >> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/d/optout. >> > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com >If you have another machine, it's worth a try on that machine too.
-- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.On Sat, Sep 6, 2014 at 3:13 PM, Cesar Renteria Marin renteriamarin@gmail.com wrote:
over after this error.El martes, 2 de septiembre de 2014 11:01:42 UTC-5, Mitch Sundt escribió:
http://opendatakit.org/use/aggregate/On Mon, Sep 1, 2014 at 1:04 PM, Yaw Anokwa yan...@nafundi.com wrote:
Hi Cesar,
setup, professional support, and software development for ODK.On Sun, Aug 31, 2014 at 4:34 PM, Cesar Renteria Marin renter...@gmail.com wrote:
results
box
Groups
an
mitche...@gmail.com--
Also, if it is a Windows system, I suspect there is a problem with your
Path variable.
The 'System variables' value for the Path variable should start with
%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0;
it is likely that one or both of these settings are incorrect.
A quick check is to open a cmd window and type
echo %Path%
You should see something like this ( this is directly from my system, so it
includes development tools after the initial set of directories )
*C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;*C:\Users\Administrator\apache-maven-3.0.4\bin;C:\Program
Fil
es\TortoiseHg;C:\Program Files
(x86)\Android\android-sdk\platform-tools;C:\User
s\Administrator\apache-ant-1.9.4\bin;C:\Program
Files\Java\jdk1.7.0_25\bin;C:\Pr
ogram Files\Microsoft Network Monitor 3;C:\Program
Files\TortoiseSVN\bin;C:\Pro
gram Files\Groovy\groovy-2.0.0\bin;C:\Users\Administrator\fsum;C:\Program
Files
(x86)\Android\android-sdk\tools;C:\Program Files\Intel\WiFi\bin;C:\Program
File
s\Common Files\Intel\WirelessCommon;C:\Program Files\nodejs;C:\Program
Files\G
radle\gradle-1.12\bin;c:\php-5.5.15-Win32-VC11-x64;C:\Program
Files\Google\Cloud
SDK\google-cloud-sdk\bin;C:\Program Files\Intel\WiFi\bin;C:\Program
Files\Comm
on Files\Intel\WirelessCommon;C:\Users\Administrator\AppData\Roaming\npm
On Sat, Sep 6, 2014 at 12:40 PM, Yaw Anokwa wrote:If you have another machine, it's worth a try on that machine too.
OS?About Java, yes, I read carefully instructions before I tried, and over
and
Hi Cesar,
results
box
Groups
send
an
Groups
an
Thanks Yaw and Mitch!
