Sum for indexed repeat
I'm trying to sum (not count) the responses in a form; respondents assign an approximate percentage of different land covers on a route, which has to add up to 100%, and I want to constrain the form to that, and show them a warning when the result is incorrect.
I'm using odk collect v1.22.4 and pyxform, on linux mint 19.
I've tried to use the sum as a repeat group, but it only refers to the first percentage that has been registered.cocos_function.xlsx (8.2 KB)
Besides this, I would like field-list appearance to work with repeats,
thanks
Hello Eliodiaz.
Trust you are doing well.
Check this out?
https://docs.opendatakit.org/form-repeats/#id7
