Hi, I don't know how to best explain this so I'll use the scenario at hand, We have area with 5 different rooms, each room requires its own form and candidates move from one room to the next using a unique Identifier, answered of questions asked in some forms will be required in other forms as the candidate moves along, the unique identifier is then entered into the form and some fields would then be preloaded, Do you think this architecture is feasible using ODK forms, if yes, how can one go about it? Thanks..
I don't think you can do it with the Vanila ODK. Customized solutions may help, such as SurveyCTO and rtSurvey.
Hi @adobe! One approach I've seen is to have the candidate move with the device. Would that approach work in your scenario?
