Syntax validity
<selected(${demographic_residence}, 2, 3, 4, 5, 6)> is this code correct in syntax for conditionally showing question in relevance column in xls form
creating xls form for uploading to odk aggreate
Probably not. selected() is used to see if a (single) string that you want to check is among those selected in a multi-select; eg selected(${answer},'blue')
Inferring that your demographic_residence is a multi-select, whose item values are '1', '2', '3', etc, then you will need to explicitly check whether each of these has been selected; eg
selected(${demographic_residence},'2') or selected(${demographic_residence},'3') or ... and so on
thank you. it worked.
