Now that we have some basic CI in place, it seems like the next step
is to get a testing framework in place so we can start running tests
against pull requests.
Here again, I think it'd be great to get some feedback from the
community. Is Robolectric what most people use?
I am a big fan of Robolectric for unit tests. I use Robolectric for unit
tests and I use Espresso for integration tests or when I actually need
tests to run on a real device (or emulator). This is a relatively common
setup. At Google, for instance, many Android projects use Robolectric for
unit tests and then also have integration tests.
For those not familiar with Robolectric, it allows Android code to be run
in the JVM. It does this by running against real AOSP source code and it
exposes more state than native Android to support more assertions. There
are some tradeoffs with this approach. Sometimes things run on Robolectric
but not Android or vice versa. I encountered a bug testing
PreferenceFragments, for example, where Android accepted a raw int value or
an org.odk.R resource value, but Robolectric accepted only the resource
value. (I can't remember now why this mattered, but it did.) There is also
generally a delay in getting support for the latest Android versions. The
Robolectric shadows for Nougat aren't out yet, for example. In general
these are soluble problems and for me the benefits far outweigh the
drawbacks.
On Thu, Sep 8, 2016 at 3:26 AM, Yaw Anokwa wrote:
Hi all,
We use Espresso, UI Automator, and the Android JUnit 4 framework for our
unit and integration tests. As a result, our tests must be run on a device
or an emulator.
Clarice
drawbacks.
I posted this response to Yaw in an email, but it occurs to me that he likely was hoping we'd send it out to the greater community!
We have kind of 4 pronged testing approach for our code currently:
Pure Java Tests [JQuery, running on Jenkins] - For the code that runs on Android as well as on our REPL tools, server tools, etc. This covers most XForm/JavaRosa engine tests, as well as the CommCare engine tests, and run super fast.
Android Mock Tests [Robolectric, running on Jenkins] - These are tests for Android functionality that are tested against "Android Code" through mocks/shadow objects provded by http://robolectric.org/ . These run pretty fast overall, but involve a lot of setup/teardown.
"On Device" Regression Tests [Calabash, running on Amazon Device Cloud] - These are tests that are running the actual binary code against an actual device in real time with user-input level events through the calabash-android system. The device cloud lets us run them against real devices in a well managed way (that eliminates finicky ADB bullshit). The tests are sandboxed, so they don't have access to, say, the camera, and can only run against our APK (can't test integrations). These are slow as fuck (As you can guess).
"On Device" Integration Tests [Calabash, running on a server in our closet] - These are similar to the previous tests, but since we are running on our own hardware we can do things like pull down the notifications bar, or execute ADB commands to perform management actions, or check the state on the server.
Robolectric is really great, but I will say it is super annoying how fast it turns over new versions, and how much time we spend re-connecting stuff when either it, or the android SDK's get big changes.
We are still fully rolling out our Callabash strategy, and it's a fantastic stand-in for manual QA/Regression/Integration testing, but we also haven't yet quite crossed the threshold where we make big changes and have to face the burden of updating the scripts a bunch to reflect changes in the UI, so it's hard to say how much we'll love it in a few years.
I will say that these tools are great, and much more useful than they were 2 years ago, but they still feel quite immature to me (the actual calabash scripting documentation is in the "if you want to know what you can do, inspect the source code!" state). This feels like a place where shops treat their internal testing stack as a proprietary advantage against other firms and don't want to document or build communities around them. There are enough people using them that I think they will still be around in a few years, but I honestly am not quite convinced their developers won't disappear in 9 months and never come back.
-Clayton
On Thursday, September 8, 2016 at 6:26:48 AM UTC-4, Yaw Anokwa wrote:
> Hi all,
> Thanks,
> Yaw
I am Lokesh Nandanwar, a second year undergraduate student at National
Institute of Technology and Science, Durgapur, India. I found the idea:
"ODK Collect - Adding system/operational testing" For GSoC'17 very
interesting.
I have a 1.5 years of experience in developing android apps. I have already
developed 3 Android applications. My recent app was Weather++, which is a
my version of weather forecast app. This app features Sync location,
Notification alert, Maps, etc. The app is available on the play store and
can be found here:Play Store https://play.google.com/store/apps/details?id=com.lokeshkvn.android.weather.
The repository of the app can be found on github :Weatherpp https://github.com/lokeshkvn/Weatherpp.
I also has little experience in Functional Testing(Unit testing) of Android
Applications as I have implemented it in my application Github repo :
Sunshine <https://github.com/lokeshkvn/Sunshine-Version .>
I have also worked in front end Web Development for bulding website for my
Institute's Robotics Club. Github Repo :Robocell https://github.com/lokeshkvn/MY-ROBOCELL
Any reason why you haven't added Roboelectric to the mix?
On Mon, Sep 12, 2016 at 5:44 AM, clarice larson wrote:
> Hi Yaw,
> or an emulator.
> Clarice
>> tests and I use Espresso for integration tests or when I actually need tests
>> to run on a real device (or emulator). This is a relatively common setup. At
>> Google, for instance, many Android projects use Robolectric for unit tests
>> exposes more state than native Android to support more assertions. There are
>> some tradeoffs with this approach. Sometimes things run on Robolectric but
>> not Android or vice versa. I encountered a bug testing PreferenceFragments,
>> for example, where Android accepted a raw int value or an org.odk.R resource
>> value, but Robolectric accepted only the resource value. (I can't remember
>> now why this mattered, but it did.) There is also generally a delay in
>> getting support for the latest Android versions. The Robolectric shadows for
>> Nougat aren't out yet, for example. In general these are soluble problems
>> and for me the benefits far outweigh the drawbacks.
>> The Robolectric homepage gives some examples of what these tests look
>> like, and their github has more information. My Collect repackaging has
>> Robolectric tests for the components I added and demonstrates what it would
>> look like to incorporate it into a Collect build.
>>> Hi all,
>>> Thanks,
>>> Yaw
>>> You received this message because you are subscribed to the Google Groups
>>> "ODK Developers" group.
>>> To unsubscribe from this group and stop receiving emails from it, send an
>>> email to opendatakit-developers+unsubscribe@googlegroups.com.
>>> For more options, visit https://groups.google.com/d/optout.
A recent Collect PR adding tests (woohoo!) would benefit from a decision on
whether or not to use Robolectric or just instrumentation tests:
Specifically look at the TextUtils.java file there to see the discussion.
I would vote to use Robolectric. If that is agreed as as reasonable
decision, I can put together a PR adding it with a basic example.
If not, we'll have to choose something else to allow the PR author to
proceed.
run super fast.
(As you can guess).
on the server.
-Clayton
Hi all,
On Sat, Mar 4, 2017 at 3:54 AM, Lokesh Nandanwar wrote:
> Hello Everyone,
> Institute of Technology and Science, Durgapur, India. I found the idea: "ODK
> Collect - Adding system/operational testing" For GSoC'17 very interesting.
> developed 3 Android applications. My recent app was Weather++, which is a my
> can be found here:Play Store. The repository of the app can be found on
> github :Weatherpp.
> Sunshine
> My Github profile : https://github.com/lokeshkvn
> Should I start discussing the idea ?
> Thanks & Regards,
> Lokesh Nandanwar,
> National Institute of Technology, Durgapur, India
The vanilla JUnit tests are fine for simpler unit tests at the bottom
layers of an app (utility classes).
Roboelectric and Mockito are better for subsystem testing in the middle
layers of an app, where you have to mock interfaces below the subsystem.
However, because we have a high rate of change in our interfaces,
maintaining subsystem tests for the middle layers is very expensive and not
currently an efficient use of developer time.
Instead, most of our tests involve some type of integration or end-to-end
testing, which is ideal for detecting regressions as we shift and adjust
the interfaces within. Running androidTest suites solves that
integration-testing and end-to-end regression testing need.
e.g., for ODK Tables and ODK Survey, much of the functionality relies on a
calls into the services layer provided by ODK Services.
On Fri, Sep 16, 2016 at 6:23 AM, Yaw Anokwa wrote:
Clarice,
On Mon, Sep 12, 2016 at 5:44 AM, clarice larson clarlars@gmail.com wrote:
Hi Yaw,
device
or an emulator.
tests
setup. At
tests
run
There are
but
resource
remember
shadows for
problems
would
