Hi all
We are just exploring our next phase of recording activity in Guyana. And
one theme is water.
We are at the early stages of planning what to record but it is looking
like a combination of flow, turbidity which can be tested by conventional
low tec mechanisms - but we may also be looking to test quality of water
and look for Alkalinity, Ammonia, Chloride, Chlorine, Chromium, Copper,
Dissolved Oxygen/BOD, Hardness, Iron, Nitrate, pH, Phosphate etc
Question, has anyone any experience in this area, and in particular the
integration/use with ODK collect.
We have found a couple of interesting technologies - one that connects to
the phone
and one that is an independent device
http://www.hachco.ca/product.detail-overview.jsa?id=15684103253
Am keen not to create a different recording system and data/analysis flow
because of this new recording theme - so wondering if anyone is doing this
with ODK.
Thanks in advance
Jon
Hi Jon,
I don't have experience using ODK Collect for this, but here is my 2 cents
anyway:
I would personally try not to be dependent on dedicated measuring +
collection equipment, because I imagine there will always be parameters
that you'd like to measure but are not included in the equipment. Using
manual entry in an ODK Collect or Enketo form would seem attractive to me
for this reason (you can using any sensors - including perfectly adequate
manual ones like turbidity tubes - and testing equipment, and e.g. add
sanitary survey questions, but manually record the values in your form with
ODK Collect or Enketo). Of course, it does increase the potential for human
error in reading/entering values which can only partially be addressed with
clever constraints.
In addition, using complex form logic, you could also provide an efficient
on-the-spot analysis of overall water safety/risk in a step-by-step process
(e.g. a different water quality parameters depending on the type of water
source, exclude measuring residual chlorine if the turbidity is high, etc,
and calculating a final result at the end of the form).
Cheers,
Martijn
On Monday, October 28, 2013 2:55:26 AM UTC-6, Jon Parsons wrote:
> Hi all
> one theme is water.
> the phone
> http://postscapes.com/mobile-water-sensing-mobosens
> with ODK.
> Thanks in advance
> Jon
Good stuff Martijn,
One thing we noticed on using the very complex forms, the small 3.5"
screens just does not cut it....
I like your suggestions.
Rox.
On Tue, Oct 29, 2013 at 10:47 AM, Martijn van de Rijdt wrote:
Hi Jon,
anyway:
clever constraints.
Cheers,
Martijn
Hi all
one theme is water.
the phone
http://postscapes.com/mobile-**water-sensing-mobosenshttp://postscapes.com/mobile-water-sensing-mobosens
http://www.hachco.ca/product.**detail-overview.jsa?id=**15684103253http://www.hachco.ca/product.detail-overview.jsa?id=15684103253
with ODK.
Thanks in advance
Jon
"Like a camera I use the negative to develop..uDig"
"Success is the ability to go from one failure to another with no loss of
enthusiasm"
Roxroy K. Bollers
OutSourceRox*
*Geographic Information Systems, IT Professional & Wed Developer
tel. 592.685.2737
Follow Us On
Facebook http://www.facebook.com/OutSourceRox
Google+ https://plus.google.com/114064153117817313312
Web http://twitinternational.com/outsourcerox.htm
Twitter: @drbollers http://www.twitter.com/drbollers
Portfolio:
Tropical Timber http://www.tropicaltimber.com
Adventure Guianas http://www.adventureguianas.com/
Surama Eco-Lodge http://www.suramaecolodge.com/
Forest Connect Guyana http://iwokrama.org/forestconnect/index.htm
Maybe consider using tablets with either ODK Collect or Enketo depending on
your needs (some key differences between them in the table on this
pagehttps://enketo.org/openrosa
Good luck,
Martijn
On Wed, Oct 30, 2013 at 7:45 AM, Roxroy Bollers wrote:
Good stuff Martijn,
Rox.
On Tue, Oct 29, 2013 at 10:47 AM, Martijn van de Rijdt <martijn@enketo.org wrote:
Hi Jon,
cents anyway:
clever constraints.
efficient on-the-spot analysis of overall water safety/risk in a
step-by-step process (e.g. a different water quality parameters depending
on the type of water source, exclude measuring residual chlorine if the
turbidity is high, etc, and calculating a final result at the end of the
form).
Cheers,
Martijn
Hi all
And one theme is water.
to the phone
flow because of this new recording theme - so wondering if anyone is doing
this with ODK.
Thanks in advance
Jon
enthusiasm"
Roxroy K. Bollers
OutSourceRox*
tel. 592.685.2737
Follow Us On
Portfolio:
https://groups.google.com/d/topic/opendatakit/kNpVm2QDpWU/unsubscribe.
Enketo https://enketo.org |
LinkedInhttp://www.linkedin.com/company/enketo-llc |
GitHub https://github.com/MartijnR
Hey Martijn,
That was very informative. As I will be starting a new project which will
be focusing on data collecting using mobile device, so these ideas are
good. One question I do have for the enketo - is it possible for that to
work in a NON CLOUD environment?
The area where project will be establish would not have internet, neither
mobile data service so as much as I want to use mobile handsets to aid in
data collection, I need to be able to get the data off the phone and into
my mapping prog.
Rox.
on your needs (some key differences between them in the table on this pagehttps://enketo.org/openrosa
Good luck,
Martijn
On Wed, Oct 30, 2013 at 7:45 AM, Roxroy Bollers rkbollers@gmail.comwrote:
Good stuff Martijn,
Rox.
On Tue, Oct 29, 2013 at 10:47 AM, Martijn van de Rijdt < martijn@enketo.org> wrote:
Hi Jon,
cents anyway:
clever constraints.
form).
Cheers,
Martijn
Hi all
to the phone
this with ODK.
Thanks in advance
Jon
enthusiasm"
Roxroy K. Bollers
OutSourceRox*
tel. 592.685.2737
Follow Us On
Portfolio:
Enketo https://enketo.org | LinkedInhttp://www.linkedin.com/company/enketo-llc |
enthusiasm"
Roxroy K. Bollers
OutSourceRox*
tel. 592.685.2737
Follow Us On
Portfolio:
Hi Rox,
Enketo requires a compatible data/form server in the cloud, such as an
installation of ODK Aggregate or Formhub.
Enketo itself (the data collection web app) requires an occasional Internet
connection to:
- 'install' the application,
- keep it up to date and,
- upload locally saved records.
'Installing' simply means opening the form in your mobile browser and
waiting a few seconds until you see the red icon in the top left. You could
e.g. do this via a internet-connected wifi network in the office/tent/car.
After that you can go into the field and collect data. You will be able to
open the form without an internet connection and save data persistently in
the browser. You'll see the amount of records queued in the top right of
the form. When data collection is finished, the device can be returned to
the office/tent/car (with the Internet-connected wifi network). Opening the
form when connected will automatically start uploading the data (to your
installation of ODK Aggregate or Formhub).
So it's a web app designed for contexts with poor and intermittent Internet
Connectivity but it requires Internet access occasionally.
Cheers,
Martijn
On Wed, Oct 30, 2013 at 2:49 PM, Roxroy Bollers wrote:
Hey Martijn,
my mapping prog.
Rox.
On Wed, Oct 30, 2013 at 11:35 AM, Martijn van de Rijdt <martijn@enketo.org wrote:
page https://enketo.org/openrosa).
Good luck,
Martijn
Good stuff Martijn,
Rox.
Hi Jon,
cents anyway:
clever constraints.
form).
Cheers,
Martijn
Hi all
looking like a combination of flow, turbidity which can be tested by
conventional low tec mechanisms - but we may also be looking to test
quality of water and look for Alkalinity, Ammonia, Chloride, Chlorine,
Chromium, Copper, Dissolved Oxygen/BOD, Hardness, Iron, Nitrate, pH,
Phosphate etc
the integration/use with ODK collect.
to the phone
this with ODK.
Thanks in advance
Jon
of enthusiasm"
Roxroy K. Bollers
OutSourceRox*
tel. 592.685.2737
Follow Us On
Portfolio:
enthusiasm"
Roxroy K. Bollers
OutSourceRox*
tel. 592.685.2737
Follow Us On
Portfolio:
Hi Martin,
Great software I really like it. You can also use Enketo from a Smap
Server now. Just select the "Web Forms" menu option.
regards
Neil
On Thu, Oct 31, 2013 at 8:41 AM, Martijn van de Rijdt wrote:
Hi Rox,
Internet connection to:
Internet Connectivity but it requires Internet access occasionally.
Cheers,
Martijn
On Wed, Oct 30, 2013 at 2:49 PM, Roxroy Bollers rkbollers@gmail.comwrote:
Hey Martijn,
my mapping prog.
Rox.
On Wed, Oct 30, 2013 at 11:35 AM, Martijn van de Rijdt < martijn@enketo.org> wrote:
Good luck,
Martijn
Good stuff Martijn,
Rox.
Hi Jon,
cents anyway:
clever constraints.
form).
Cheers,
Martijn
Hi all
Phosphate etc
connects to the phone
this with ODK.
Thanks in advance
Jon
of enthusiasm"
Roxroy K. Bollers
OutSourceRox*
tel. 592.685.2737
Follow Us On
Portfolio:
enthusiasm"
Roxroy K. Bollers
OutSourceRox*
tel. 592.685.2737
Follow Us On
Portfolio:
Smap Consulting http://smap.com.au/| Mobile Data Collection Solutions
Application Developer - neilpenman@gmail.com minqiang.huang@gmail.com
Twitter: @dgmsot
Skype: ianaf4you
Phone: +61 402 975 959
Blog: http://blog.smap.com.au http://smap.com.au/blog
Thanks Neil,
I will be expecting code contributions for the new
enketo-corehttps://github.com/MartijnR/enketo-corewhen it is stable
in 1 or 2 weeks!
Cheers,
On Wed, Oct 30, 2013 at 4:50 PM, Neil Penman wrote:
Hi Martin,
regards
Neil
On Thu, Oct 31, 2013 at 8:41 AM, Martijn van de Rijdt martijn@enketo.orgwrote:
Hi Rox,
Cheers,
Martijn
Hey Martijn,
will be focusing on data collecting using mobile device, so these ideas are
neither mobile data service so as much as I want to use mobile handsets to
aid in data collection, I need to be able to get the data off the phone and
into my mapping prog.
Rox.
depending on your needs (some key differences between them in the table onthis pagehttps://enketo.org/openrosa
Good luck,
Martijn
Good stuff Martijn,
Rox.
Hi Jon,
cents anyway:
clever constraints.
form).
Cheers,
Martijn
Hi all
Guyana. And one theme is water.
Phosphate etc
this with ODK.
Thanks in advance
Jon
send an email to opendatakit+unsubscribe@googlegroups.com.
of enthusiasm"
Roxroy K. Bollers
OutSourceRox*
tel. 592.685.2737
Follow Us On
Portfolio:
of enthusiasm"
Roxroy K. Bollers
OutSourceRox*
tel. 592.685.2737
Follow Us On
Portfolio:
Twitter: @dgmsot
Skype: ianaf4you
Hi Martin,
I have passed this email onto the students from RMIT who added Enketo to
the Smap server. Hopefully they will have time soon to work on some new
features.
regards
Neil
On Thu, Oct 31, 2013 at 11:04 AM, Martijn van de Rijdt wrote:
Thanks Neil,
I will be expecting code contributions for the new enketo-corehttps://github.com/MartijnR/enketo-corewhen it is stable in 1 or 2 weeks!
Cheers,
On Wed, Oct 30, 2013 at 4:50 PM, Neil Penman neilpenman@gmail.com wrote:
Hi Martin,
regards
Neil
On Thu, Oct 31, 2013 at 8:41 AM, Martijn van de Rijdt <martijn@enketo.org wrote:
Hi Rox,
Cheers,
Martijn
Hey Martijn,
Rox.
Good luck,
Martijn
Good stuff Martijn,
Rox.
Hi Jon,
cents anyway:
clever constraints.
form).
Cheers,
Martijn
Hi all
Phosphate etc
data/analysis flow because of this new recording theme - so wondering if
anyone is doing this with ODK.
Thanks in advance
Jon
loss of enthusiasm"
Roxroy K. Bollers
OutSourceRox*
tel. 592.685.2737
Follow Us On
Portfolio:
the Google Groups "ODK Community" group.
of enthusiasm"
Roxroy K. Bollers
OutSourceRox*
tel. 592.685.2737
Follow Us On
Portfolio:
Twitter: @dgmsot
Skype: ianaf4you
Twitter: @dgmsot
Skype: ianaf4you
