Text Length of hint or Question in ODK
What's the number of text length of hint or question in ODK?
When I use 348 text length in hint, it works. But it doesn't work when I use 420 length in hint.
Any how?
The solution has been discussed on this topic. You need to edit the XML file to increase the length of text.
@A.N.M_AL-IMRAN has the solution for you if you're talking about hitting a limit when entering new data. It doesn't require modifying XML, though, and you can find documentation at https://docs.opendatakit.org/aggregate-field-length/.
That said, it sounds like you are talking about experiencing a limit in the length of the hint itself. Is that correct, @Tun_Lin_gpt? Can you please let us know what device you are using, what Android version and what you see when you include 420 characters?
