Hi?
I followed am trying to have a choice filters that filters options form
region, down through to name of employees in each district, and job
positions of each employee within a district.
See the file attached.
How ever, when I try to convert the file into a form, it shows "There has
been a problem trying to replace ${region} with the XPath to the survey
element named 'region'. There is no survey element with this name."
Any assistance to rectify the issue is much appreciated. Thank you in
advance.
Louis.
FILTERING_XLSFORM_TEMPLATE.xlsx (17.1 KB)
Louis,
Column 'name' identifies the element (variable) to be referenced. In your case the region element should be 'Q01' and so to reference it put this '${Q01}'.
McAdoyo.
-----Original Message-----
Sent: 10/11/2015 5:59 PM
To: "ODK Community" ; "Yaw Anokwa"
Subject: [ODK Community] There has been a problem trying to replace ${region}with the XPath to the survey element named 'region'. There is no surveyelement with this name.
Hi?
I followed am trying to have a choice filters that filters options form region, down through to name of employees in each district, and job positions of each employee within a district.
How ever, when I try to convert the file into a form, it shows "There has been a problem trying to replace ${region} with the XPath to the survey element named 'region'. There is no survey element with this name."
Any assistance to rectify the issue is much appreciated. Thank you in advance.
Louis.
Le dimanche 11 octobre 2,015 15:59:58 UTC + 1, Louis Omoya a écrit:
FILTERING_XLSFORM_TEMPLATE.xlsx (19 KB)
> Salut?
> Je suivais AM essayant d'avoir un filtres de choix que les options des
> filtres forment la région, à travers au nom des employés dans chaque
> district, et les postes de travail de chaque employé au sein d'un district.
> Voir le fichier joint.
> Comment jamais, lorsque je tente de convertir le fichier dans un
> formulaire, il montre "Il ya eu un problème d'essayer de remplacer $
> {région} avec le XPath à l'élément d'enquête nommée« région ». Il n'y a
> aucun élément d'enquête avec ce nom. "
> Toute aide pour rectifier le problème est très apprécié. Merci d'avance.
> Louis.
Thank you very much.
This really helps clarify things
On Sun, Oct 11, 2015 at 6:42 PM, Collins Adoyo wrote:
Louis,
'${Q01}'.
McAdoyo.
To: ODK Community opendatakit@googlegroups.com; Yaw Anokwa
yanokwa@nafundi.com
Hi?
advance.
Louis.
