Is there any way to create questionnaire with third party string tool in XLSForm
(formerly XLS2Xform)??? I have tried in XML but I have a long questionnaire
so i waned it to be done in simplified way. If something exists to create
such forms in XLSForm (formerly XLS2Xform) level please do give me
information. Any help would be appreciated.
I don't understand your question. What 'third party string' tool are you
referring to?
If you want to use the 'String from 3rd party app' widget, you would simply
create an 'appearance' column in the XLS survey sheet and specify an
appropriate appearance string. e.g., from the examples sheet ( http://opendatakit.org/help/form-design/examples/ )
ex:org.thirdparty.app.ActivityName
On Tue, Apr 2, 2013 at 12:29 AM, Joseph wrote:
Dear all,
