Hey group,
I'm working on a project to use 30 or so tablets (Samsung Tab 3s) to
collect hospital data across a country. For the first year or so, our
partner wants everything to run completely offline so we're using
Briefcase. I've found that how I've chosen to use Briefcase involves a lot
of manual steps which are laborious and prone to human error. As I will
be training an overworked data manager on this, I'd like to make the steps
as simple and short as possible. Below are the current steps I have along
with some question/comments. If anyone has pro-tips on how to
automate/skip/simplify I'd be grateful. I'm also going to research and if
I come up with anything will post back to this thread.
Copying instances off tablet onto computer, into briefcase and exported out
as a csv
- Reset tablet and connect tablet to computer via cable
- Copy "odk" folder from tablet1 to C:/TabletData/Tablet1, and so on for
each tablet.
- Open ODK Briefcase and one by one, pull instances from every C:/TabletData/
folder.
- Export data to csv
*based on previous responses in this group, it seems step 2 is an annoying
but necessary step
*i was hoping to at least bypass step #3 by copying the instances from each
"C:/TabletData/Tabletwhatever/odk/forms/instances" directly into the "C:\ODK
Briefcase Storage\forms\GrilledeSupervisionTest\instances" but this failed
"Starting Export...
Submission not found for instance directory: C:\ODK Briefcase
Storage\forms\GrilledeSupervisionTest\instances\grilledesupervision2
(4)_2013-08-07_12-58-42
FAILED!"
In the unfortunate event that an instance needs to be modified after it has
already been imported, I have the following steps.
- Delete all instances from ODK Briefcase
- Delete all instances from appropriate tablet folder on C:/TabletData/
- Open relevant instance on tablet and modify and save.
- Copy "odk" folder from tablet to appropriate folder on C:/TabletData/
folder.
I'm hoping someone out there has already figured out a smarter way. HELP!
Respect,
Bill
Hi Bill,
Sorry to hear about your data collection troubles.
If you can setup a WiFi connection between the tablets and the
computers, you can install Aggregate on the laptop and skip much of
importing.
As far as editing data goes, that probably shouldn't be done on the
tablet. Once you've submitted the data, consider it final. Export it
into some master file and make those changes there.
Have you tried pushing back on your partner? If you explain that the
offline requirement results in a laborious and error prone, they might
change their mind.
I understand that you have some process that you need to follow, but a
little bit of flexibility will save you a lot of heartache. And if you
can't be flexible in the process, then you'll just have to find some
way to write software (or find some software) that does exactly what
you need.
Good luck,
On Mon, Mar 17, 2014 at 5:48 AM, Bill Olander billyolander@gmail.com wrote:
Hey group,
partner wants everything to run completely offline so we're using Briefcase.
I've found that how I've chosen to use Briefcase involves a lot of manual
steps which are laborious and prone to human error. As I will be training
an overworked data manager on this, I'd like to make the steps as simple and
short as possible. Below are the current steps I have along with some
question/comments. If anyone has pro-tips on how to automate/skip/simplify
I'd be grateful. I'm also going to research and if I come up with anything
as a csv
each tablet.
C:/TabletData/ folder.
but necessary step
"Starting Export...
FAILED!"
Respect,
Bill
Hey Yaw,
Thanks for replying back to me.
I realize I never quite understood AggregateVM (thanks for building it),
but now will try to push for it to be used. Using that will skip a number
of steps.
Much Respect!
Bill
On Tuesday, March 18, 2014 4:39:26 AM UTC, Yaw Anokwa wrote:
> Hi Bill,
> importing.
> change their mind.
> you need.
> Good luck,
> Yaw
> On Mon, Mar 17, 2014 at 5:48 AM, Bill Olander <billyo...@gmail.com> wrote:
> > Hey group,
> Briefcase.
> manual
> training
> and
> anything
> out
> > as a csv
> > 1. Reset tablet and connect tablet to computer via cable
> > 2. Copy "odk" folder from tablet1 to C:/TabletData/Tablet1, and so on
> for
> > each tablet.
> > 3. Open ODK Briefcase and one by one, pull instances from every
> > 4. Export data to csv
> annoying
> > but necessary step
> each
> "C:\ODK
> failed
> > "Starting Export...
> > FAILED!"
> has
> > 1. Delete all instances from ODK Briefcase
> > 2. Delete all instances from appropriate tablet folder on
> C:/TabletData/
> > 3. Open relevant instance on tablet and modify and save.
> > 4. Reset tablet and connect tablet to computer via cable
> > 5. Copy "odk" folder from tablet to appropriate folder on
> C:/TabletData/
> HELP!
> > Respect,
> > Bill
> Groups
> > "ODK Community" group.
> an
Hi Bill,
The VM is not without its warts, but if you can make sure it's on the
same network as your devices, and that its IP does not change, it
should work for you.
On Fri, Mar 21, 2014 at 3:04 AM, Bill Olander billyolander@gmail.com wrote:
Hey Yaw,
of steps.
Much Respect!
Bill
Hi Bill,
importing.
change their mind.
you need.
Good luck,
On Mon, Mar 17, 2014 at 5:48 AM, Bill Olander billyo...@gmail.com wrote:
Hey group,
Briefcase.
manual
training
and
anything
out
as a csv
for
each tablet.
annoying
but necessary step
each
"C:\ODK
failed
"Starting Export...
FAILED!"
has
C:/TabletData/
C:/TabletData/
HELP!
Respect,
Bill
Groups
an
Hi Yaw,
It took a little playing around, but i finally found it was easy enough
to assign a fixed ip adress via the router's settings menu.
Is there any thing else, any "warts" to be wary of when using
AggregateVM? With the ip adress fixed, its been smooth sailing.
Bill
On Friday, March 21, 2014 1:48:55 PM UTC, Yaw Anokwa wrote:
> Hi Bill,
> Yaw
> On Fri, Mar 21, 2014 at 3:04 AM, Bill Olander <billyo...@gmail.com> wrote:
> > Hey Yaw,
> it),
> number
> > of steps.
> > Much Respect!
> > Bill
> >> Hi Bill,
> >> importing.
> >> change their mind.
> >> you need.
> >> Good luck,
> >> Yaw
> >> On Mon, Mar 17, 2014 at 5:48 AM, Bill Olander wrote:
> >> > Hey group,
> to
> our
> >> > Briefcase.
> >> > manual
> >> > training
> simple
> >> > and
> some
> >> > anything
> exported
> >> > out
> >> > as a csv
> on
> >> > for
> >> > each tablet.
> >> > annoying
> >> > but necessary step
> from
> >> > each
> >> > "C:\ODK
> >> > failed
> >> > "Starting Export...
> >> > FAILED!"
> it
> >> > has
> >> > C:/TabletData/
> >> > C:/TabletData/
> >> > HELP!
> >> > Respect,
> >> > Bill
> >> > Groups
> send
> >> > an
> Groups
> an
Bill,
What we know about is what is in the read me and at
https://bitbucket.org/nafundi/odk-aggregate-vm/issues.
On Sun, Apr 6, 2014 at 3:10 AM, Bill Olander billyolander@gmail.com wrote:
Hi Yaw,
It took a little playing around, but i finally found it was easy enough to
Is there any thing else, any "warts" to be wary of when using AggregateVM?
Bill
Hi Bill,
On Fri, Mar 21, 2014 at 3:04 AM, Bill Olander billyo...@gmail.com wrote:
Hey Yaw,
it),
number
of steps.
Much Respect!
Bill
Hi Bill,
importing.
change their mind.
you need.
Good luck,
Hey group,
to
our
Briefcase.
manual
training
simple
and
some
anything
exported
out
as a csv
on
for
each tablet.
annoying
but necessary step
from
each
"C:\ODK
failed
"Starting Export...
FAILED!"
it
has
C:/TabletData/
C:/TabletData/
HELP!
Respect,
Bill
Groups
send
an
Groups
an
