With formhub when people submit photos over a slower connection we're
getting a 500 error on submissions. Mostly likely we think it's due to a
connection time out.
We were wondering how you handled this with Aggregate or if this is an
error ODK collect users will experience given similar circumstances?
Just wondering if you had any advice as we dig into this.
Matt
File
"/home/wsgi/srv/ei_surveyor_alpha/project_env/lib/python2.6/site-packages/django/core/handlers/base.py",
line 111, in get_response
response = callback(request, *callback_args, **callback_kwargs)
File
"/home/wsgi/srv/ei_surveyor_alpha/project_env/lib/python2.6/site-packages/django/views/decorators/http.py",
line 45, in inner
return func(request, *args, **kwargs)
File
"/home/wsgi/srv/ei_surveyor_alpha/project_env/lib/python2.6/site-packages/django/views/decorators/csrf.py",
line 39, in wrapped_view
resp = view_func(*args, **kwargs)
File
line 52, in wrapped_view
return view_func(*args, **kwargs)
File "/home/wsgi/srv/ei_surveyor_alpha/formhub/odk_logger/views.py", line
75, in submission
xml_file_list = request.FILES.pop("xml_submission_file", )
File
"/home/wsgi/srv/ei_surveyor_alpha/project_env/lib/python2.6/site-packages/django/core/handlers/wsgi.py",
line 226, in _get_files
self._load_post_and_files()
File
"/home/wsgi/srv/ei_surveyor_alpha/project_env/lib/python2.6/site-packages/django/http/init.py",
line 272, in _load_post_and_files
self._post, self._files = self.parse_file_upload(self.META, self)
File
line 234, in parse_file_upload
return parser.parse()
File
"/home/wsgi/srv/ei_surveyor_alpha/project_env/lib/python2.6/site-packages/django/http/multipartparser.py",
line 192, in parse
for chunk in field_stream:
File
line 314, in next
output = self._producer.next()
File
line 468, in next
for bytes in stream:
File
line 314, in next
File
line 375, in next
data = self.flo.read(self.chunk_size)
File
line 405, in read
return self._file.read(num_bytes)
File
line 296, in read
return self._stream.read(*args, **kwargs)
IOError: request data read error
<WSGIRequest
GET:<QueryDict: {}>,
POST:,
COOKIES:{},
META:{'CONTENT_LENGTH': '6355267',
'CONTENT_TYPE': 'multipart/form-data;
boundary=mwroxo5jQ8TAPFdswHfBIaX8tnIHSwhc',
'CSRF_COOKIE': '445289f214e66cb08f4626b88946c44c',
'DOCUMENT_ROOT': '/htdocs',
'GATEWAY_INTERFACE': 'CGI/1.1',
'HTTP_CONNECTION': 'Close',
'HTTP_DATE': 'mar, 17 janv. 2012 10:54:49 UTC+00:00',
'HTTP_HOST': 'formhub.org',
'HTTP_X_FORWARDED_FOR': '67.45.25.234',
'HTTP_X_OPENROSA_VERSION': '1.0',
'PATH':
'/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/X11R6/bin',
'PATH_INFO': u'/vte_mercycorps/submission',
'PATH_TRANSLATED':
'/home/wsgi/srv/ei_surveyor_alpha/apache/environment.wsgi/vte_mercycorps/submission',
'QUERY_STRING': '',
'REMOTE_ADDR': '69.19.14.40',
'REMOTE_PORT': '34529',
'REQUEST_METHOD': 'POST',
'REQUEST_URI': '/vte_mercycorps/submission',
'SCRIPT_FILENAME':
'/home/wsgi/srv/ei_surveyor_alpha/apache/environment.wsgi',
'SCRIPT_NAME': u'',
'SERVER_ADDR': '173.255.225.171',
'SERVER_ADMIN': 'support@formhub.org',
'SERVER_NAME': 'formhub.org',
'SERVER_PORT': '80',
'SERVER_PROTOCOL': 'HTTP/1.1',
'SERVER_SIGNATURE': 'Apache/2.2.14 (Ubuntu) Server at
formhub.org Port
80\n',
'SERVER_SOFTWARE': 'Apache/2.2.14 (Ubuntu)',
'mod_wsgi.application_group': 'ei-surveyor.mvpafrica.org|',
'mod_wsgi.callable_object': 'application',
'mod_wsgi.listener_host': '',
'mod_wsgi.listener_port': '80',
'mod_wsgi.process_group': 'ei-surveyor.mvpafrica.org',
'mod_wsgi.reload_mechanism': '1',
'mod_wsgi.script_reloading': '1',
'mod_wsgi.version': (2, 8),
'wsgi.errors': <mod_wsgi.Log object at 0xb9140a40>,
'wsgi.file_wrapper': <built-in method file_wrapper of mod_wsgi.Adapter
object at 0xb91394a0>,
'wsgi.input': <mod_wsgi.Input object at 0xb914b4d0>,
'wsgi.multiprocess': True,
'wsgi.multithread': True,
'wsgi.run_once': False,
'wsgi.url_scheme': 'http',
'wsgi.version': (1, 0)}>
