I have noticed that the format of the timestamps is different when my data
is uploaded via wifi versus when it is upload via breifcase. When I try to
run macros on exports that originated in uploads from breifcase, it bugs
out.
Im also wondering if there is a way to change the timestamp on ODK from UTC
to my current time zone.
RE: upload format
Both are trying to follow iso8601 formatting.
2011-08-30T23:29:00.698Z == indicates UTC
2012-07-27T13:47:47.435-07 == indicates 7 hr behind UTC
RE: timezone setting
No. Code contributions welcome.
out.
UTC to my current time zone.
you can try try this free online unix timestamp creator(http://www.online-code.net/unix-timestamp.html), you can get the current time stamp.
I'm not sure I understand your solution to my first concern, in terms of
running my macros without bugs from the BC derived forms.
On Fri, Aug 24, 2012 at 2:49 PM, Mitch S wrote:
RE: upload format
data is uploaded via wifi versus when it is upload via breifcase. When I
try to run macros on exports that originated in uploads from breifcase, it
bugs out.
Your script must correctly parse: http://www.w3.org/TR/NOTE-datetime
On Fri, Aug 24, 2012 at 12:45 PM, SOIL Re.Source < soilre.sourcehaiti@gmail.com> wrote:
On Fri, Aug 24, 2012 at 2:49 PM, Mitch S mitchellsundt@gmail.com wrote:
RE: upload format
bugs out.
