Too many fields defined rror
Hey all,
I downloaded results from the server using publish and was trying to join 2
sheets in the same workbook using Microsoft query function in order to get
the multiple choice questions to open up. When I get to the point where I
need to choose what columns to include in the query, i get this error "Too
many fields defined" and hence I can't continue with the query to join the
2 sheets.
Now I am assuming the problem is with the excel sheet itself . Is it that
the columns are more than 255 columns . However I have tried to reduce the
columns to less than 255 but the problem still persists. What could be the
issue because even when I use Access the error s still there. Find attached
the error.
ERROR.docx (194 KB)
This is best asked on a group that supports whatever tool you are using
(Microsoft Query).
But if you are trying to update the record, you are limited to 127
ยทยทยท On Sun, Feb 21, 2016 at 8:03 AM, Karisa Kazungu wrote:
Hey all,
2 sheets in the same workbook using Microsoft query function in order to
get the multiple choice questions to open up. When I get to the point where
I need to choose what columns to include in the query, i get this error
"Too many fields defined" and hence I can't continue with the query to join
the 2 sheets.
the error.
