I have three fields that accept integer values. I need to make sure that
the sum of the values should not exceed 100. How do I do this? This is for
percentage.
See: http://opendatakit.org/help/form-design/binding/
If using XLSForm, you can set up a constraint column with a formula like:
${field1} + ${field2} + ${field3} = 100
See http://opendatakit.org/help/form-design/xlsform/ for more info.
Note that if you are working with decimal values, and not integer values,
you will probably need to allow for some rounding error (e.g., 99.9 - 100.1
% or something like that).
On Tue, Oct 15, 2013 at 10:00 PM, Jack Elendil Lagare < jackeblagare@gmail.com> wrote:I have three fields that accept integer values. I need to make sure that
percentage.--
Where do I put this? My initial thought is to have a trigger screen that
will only display if values are greater than 100. Is there another way?
On Friday, October 18, 2013 1:44:02 AM UTC+8, Mitch Sundt wrote: > > See: http://opendatakit.org/help/form-design/binding/ > > If using XLSForm, you can set up a constraint column with a formula like: > > ${field1} + ${field2} + ${field3} = 100 > > See http://opendatakit.org/help/form-design/xlsform/ for more info. > > Note that if you are working with decimal values, and not integer values, > you will probably need to allow for some rounding error (e.g., 99.9 - 100.1 > % or something like that). > > > > On Tue, Oct 15, 2013 at 10:00 PM, Jack Elendil Lagare <jackeb...@gmail.com wrote: > >> I have three fields that accept integer values. I need to make sure that >> the sum of the values should not exceed 100. How do I do this? This is for >> percentage. >> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/groups/opt_out. >> > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com >Hi Jack,
Are you working with XLS forms or programming this by hand? I think the
best way to do this is to set a constraint on the 3rd field that will add
all fields together and set off a constraint message if your fields do not
add up to 100.
In the bindings, you want to write:
constraint="(. + field2 + field1) = 100" jr:constraintMsg="The values in
the last three fields have to add up to 100%."
That should give you a warning when that constraint is not true.
j
On Mon, Oct 21, 2013 at 8:53 PM, Jack Elendil Lagare <jackeblagare@gmail.com wrote:Where do I put this? My initial thought is to have a trigger screen that
will only display if values are greater than 100. Is there another way?On Friday, October 18, 2013 1:44:02 AM UTC+8, Mitch Sundt wrote:
See: http://opendatakit.org/help/**form-design/binding/http://opendatakit.org/help/form-design/binding/
See http://opendatakit.org/help/**form-design/xlsform/http://opendatakit.org/help/form-design/xlsform/for more info.
% or something like that).On Tue, Oct 15, 2013 at 10:00 PM, Jack Elendil Lagare < jackeb...@gmail.com> wrote:
percentage.--
Unsubscribe: opendatakit...@**googlegroups.com
Groups "ODK Community" group.
an email to opendatakit...@**googlegroups.com.
For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out
mitche...@gmail.com--
I'm programming by hand. Ok, I will try this one out. Thanks Jitka.
On Oct 22, 2013, at 10:04 AM, Jitka Hiscox wrote:Hi Jack,
Are you working with XLS forms or programming this by hand? I think the best way to do this is to set a constraint on the 3rd field that will add all fields together and set off a constraint message if your fields do not add up to 100.In the bindings, you want to write:
constraint="(. + field2 + field1) = 100" jr:constraintMsg="The values in the last three fields have to add up to 100%."That should give you a warning when that constraint is not true.
j
On Mon, Oct 21, 2013 at 8:53 PM, Jack Elendil Lagare jackeblagare@gmail.com wrote:
Where do I put this? My initial thought is to have a trigger screen that will only display if values are greater than 100. Is there another way?On Friday, October 18, 2013 1:44:02 AM UTC+8, Mitch Sundt wrote:
See: http://opendatakit.org/help/form-design/binding/If using XLSForm, you can set up a constraint column with a formula like:
Note that if you are working with decimal values, and not integer values, you will probably need to allow for some rounding error (e.g., 99.9 - 100.1 % or something like that).
On Tue, Oct 15, 2013 at 10:00 PM, Jack Elendil Lagare jackeb...@gmail.com wrote:
I have three fields that accept integer values. I need to make sure that the sum of the values should not exceed 100. How do I do this? This is for percentage.--
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com.
You received this message because you are subscribed to a topic in the Google Groups "ODK Community" group.
To unsubscribe from this topic, visit https://groups.google.com/d/topic/opendatakit/6xvJHi234i8/unsubscribe.
To unsubscribe from this group and all its topics, send an email to opendatakit+unsubscribe@googlegroups.com.
Hi guys,
I'm doing exactly the same thing (${canopy2} + ${canopy3} + ${canopy4} + ${canopy5} + ${canopy6}) = 100 and doesn't seem to be working for me.
All the variables are collected from prior page as integers and i'm using a note (type) XLSForm to emphasize with the above formula added to bind:constraint.
I'm using ODK collect 1.4.3(1040)
Richard
Hi Richard,
The community can't help unless we can see a test case with the
precise problem. I've attached a sample form that shows a totaling.
I add up everything in a calculate. Then use a note after the
calculate to show an error and require the user to go back and change
the numbers to validate. I then make the note required and relevant
when ${total} > 100.
Hope that helps,
total_warning.xlsx (9.79 KB)
-- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.On Fri, May 16, 2014 at 1:04 PM, ngamita@gmail.com wrote:
Hi guys,
Richard
Thanks Yaw, this is exactly what i wanted and didn't know i could use
required in this way. I've noted the test case requirement :).
On Sat, May 17, 2014 at 11:04 PM, Yaw Anokwa wrote:Hi Richard,
precise problem. I've attached a sample form that shows a totaling.I add up everything in a calculate. Then use a note after the
when ${total} > 100.Hope that helps,
Hi guys,
${canopy5} + ${canopy6}) = 100 and doesn't seem to be working for me.All the variables are collected from prior page as integers and i'm
bind:constraint.I'm using ODK collect 1.4.3(1040)
Richard
Cool, and if you want EXACTLY 100 only. You'll have to go with ${total} >
100 or ${total} < 100. Hope it helps someone else some day :).
On Mon, May 19, 2014 at 4:26 PM, Ngamita Richard wrote:Thanks Yaw, this is exactly what i wanted and didn't know i could use
required in this way. I've noted the test case requirement :).On Sat, May 17, 2014 at 11:04 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Hi Richard,
Hi guys,
- ${canopy5} + ${canopy6}) = 100 and doesn't seem to be working for me.
Richard
