Transferring entered data between forms on the same device
A quick question, is it possible to transfer data from the data collected in one form to another form loaded on to the same tablet. Ideally this would be something like a participant ID that is used on multiple forms o the same tablet. I'm mainly interesting in doing this with ODK Collect v1.21 upwards rather than ODK-X
ODK Collect v1.21.2
Tried using pre-loading csv file, but is not what is required.
n/a
n/a
Hi @CharlieKeyes
This feature is not available
You can check out this thread to learn more
Linking different forms.
I also encourage you to search the forum thoroughly as some answers already exist
Thanks I had a search clearly wasn't using the correct terms!
best,
C
