Hi, I need to translate the home screen and the intro message because many users do not speak English. How can I do that? Is there an xml file I can edit?
Kristof Kelemen
Kristof Kelemen
Hi Kristof,
It's based on the language of your device. Change the language of the
device and it'll change that message.
Kristof Kelemen
Hi all,
Similar question to the above but requiring a different answer. Is there a way to edit the text on the introductory page ("You are at the start of a form. When ready to begin, please click the Next button below or to the right. At the end, you will have the opportunity to submit your responses.")?
I am worried it won't be well understood in our self-administered survey with participants with weak literacy skills.
Wendy
And if you need a translation that is not listed here:
Or if a translation is not complete or needs a few corrections, please sign
up to be a translator.
Hi Kristof,
device and it'll change that message.Yaw
setup, professional support, and software development for ODK.On Fri, Oct 3, 2014 at 9:34 AM, kristof.kelemen@gmail.com wrote:
can edit?Thanks,
Kristof Kelemen
I tested, but ODK Collect still in english, my local language is Indonesian. I did finalise the transifex odk-collect translation for Indonesian. Is there any way to use the finalised id string.xml in order ODK Collect change the language?
Alex
That wording is defined by the app, not by any form that you create for the
app. To change the language of the app, including the introductory page,
you need to change the system language of your phone. That is done in
Settings (for the phone, not in the app). The app has translations for many
different languages so there is a good chance that the language you need is
supported.
-- James
can edit?Thanks,
Kristof Kelemen
Hi all,
responses.")?I am worried it won't be well understood in our self-administered survey
with participants with weak literacy skills.Thanks,
Wendy
https://groups.google.com/d/topic/opendatakit/65Xr896FzRk/unsubscribe.
And if you need a translation that is not listed here: https://www.transifex.com/projects/p/odk-collect/
Or if a translation is not complete or needs a few corrections, please sign up to be a translator.
Hi Kristof,
Kristof Kelemen
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com.
mitche...@gmail.com
I would like to translate into Hungarian, but cannot find it in the request list. I signed up to translate, what is my next step?
Kristof
Alex,
It's based on the language of your device. Have you changed the
language of the device to Indonesian?
Alex
On Friday, October 3, 2014 11:43:44 PM UTC+7, Yaw Anokwa wrote:
Hi Kristof,
Kristof Kelemen
I looks like you discovered how to request a Hungarian translation. I have
accepted your request for translation, so you should now be able to provide
the Hungarian translations.
You can download "Locale More Pro" for Android "Locale More - Language
Setting" from WOW App
https://play.google.com/store/apps/details?id=com.wowapp.localemorepro&hl=en
There is a manual setup step that you need to do on Android 4.2 and higher
devices in order to enable the setting of a locale using the app. That step
appears safe.
Once you do that step, you can then change to Nepali (or another
language/locale that is not supported by default)
I have built a version "rev 1046" of ODK Collect with the latest
translations (as of yesterday morning).
This is not on Google Play. You can download it here:
https://s3.amazonaws.com/opendatakit.downloads/ODK Collect v1.4.4 rev
1046.apk
I don't anticipate putting these on Google Play (waiting for several code
changes)
On Tue, Oct 7, 2014 at 9:21 AM, Yaw Anokwa yanokwa@nafundi.com wrote:
Alex,
language of the device to Indonesian?Yaw
setup, professional support, and software development for ODK.On Tue, Oct 7, 2014 at 7:36 AM, husn.mubarok@gmail.com wrote:
ODK Collect change the language?Alex
Hi Kristof,
can edit?Thanks,
Kristof Kelemen
Groups "ODK Community" group.To unsubscribe from this group and stop receiving emails from it,
send an email to opendatakit+unsubscribe@googlegroups.com.For more options, visit https://groups.google.com/d/optout.
Yaw,
No effect in my case. tried uninstall ODK collect, change the device
language and re-install. no luck for me, still english.
Alex,
Hi Kristof,
can edit?Thanks,
Kristof Kelemen
Have you tried Mitch's suggestion?
Language Setting" from WOW App
higher devices in order to enable the setting of a locale using the
app. That step appears safe.
On Tue, Oct 7, 2014 at 7:57 PM, Husni Mubarok husn.mubarok@gmail.com wrote:
Yaw,
language and re-install. no luck for me, still english.On Tue, Oct 7, 2014 at 11:21 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Alex,
Hi Kristof,
can edit?Thanks,
Kristof Kelemen
Mitch's suggestion not work as well, 3ed party locale more doesn't work and
rev1046 still not change the language to local device settings (indonesian)
Language Setting" from WOW Apphttps://play.google.com/store/apps/details?id=com.wowapp.localemorepro&hl=en
app. That step appears safe.Once you do that step, you can then change to Nepali (or another
language/locale that is not supported by default)Yaw
setup, professional support, and software development for ODK.On Tue, Oct 7, 2014 at 7:57 PM, Husni Mubarok husn.mubarok@gmail.com wrote:
Yaw,
Alex,
order ODK
Hi Kristof,
because
xml file I
can edit?Thanks,
Kristof Kelemen
Groups
an
Bizarre. Created issue
http://code.google.com/p/opendatakit/issues/detail?id=1072
This is very strange. The locale app correctly switches to other
non-standard locales, but does not seem to switch to id (indonesian).
This might be an issue with this particular locale-change app, or it might
be an issue with the ODK Collect build.
and rev1046 still not change the language to local device settings
(indonesian)On Wed, Oct 8, 2014 at 10:59 AM, Yaw Anokwa yanokwa@nafundi.com wrote:
Yaw,
Alex,
order ODK
Hi Kristof,
thedevice and it'll change that message.
because
xml file I
can edit?Thanks,
Kristof Kelemen
send
Groups
an
Groups
an
Hi Mitch,
I saw that you created an issue and closed it a month and a half later, but I cannot seem to find the solution/resolution.
I am running into the same problem as described in the original post with ODK Collect 1.4.5 (1048). I set the phone's language to Bahasa Indonesia (Indonesian), and ODK Collect just shows English strings in the UI. I had expected the strings to be pulled from res/values-id/strings.xml
Was this problem solved, and I am just missing the solution somewhere?
Thanks for the help!
I re-opened the issue.
Two things to try:
--- First: confirming that it is an issue ---
(1) On your device's Settings / Apps screen, choose ODK Collect, and Force
Stop it.
(2) Change the locale to id
(3) Now open ODK Collect. Does it display Indonesian? (Hopefully not)
--- Second: testing a fix ---
Download the ODK Collect build here:
https://drive.google.com/file/d/0B7g-kLY9PNUDcXNIcDhMVDdLRDQ/view?usp=sharing
And install it on your device. You will need to enable installs from
untrusted sources, and may need to use the adb tool or open your browser to
the APK file to install it. Google for instructions.
Otherwise, can you investigate whether id is the appropriate locale for
Bahasa?
Hi Mitch,
but I cannot seem to find the solution/resolution.I am running into the same problem as described in the original post with
expected the strings to be pulled from res/values-id/strings.xmlWas this problem solved, and I am just missing the solution somewhere?
http://code.google.com/p/opendatakit/issues/detail?id=1072This is very strange. The locale app correctly switches to other
non-standard locales, but does not seem to switch to id (indonesian).This might be an issue with this particular locale-change app, or it
might be an issue with the ODK Collect build.On Tue, Oct 7, 2014 at 10:16 PM, Husni Mubarok husn.m...@gmail.com wrote:
(indonesian)On Wed, Oct 8, 2014 at 10:59 AM, Yaw Anokwa yan...@nafundi.com wrote:
Have you tried Mitch's suggestion?You can download "Locale More Pro" for Android "Locale More -
On Tue, Oct 7, 2014 at 7:57 PM, Husni Mubarok husn.m...@gmail.com wrote:
Yaw,
On Tue, Oct 7, 2014 at 11:21 PM, Yaw Anokwa yan...@nafundi.com wrote:
Alex,
order ODKCollect change the language?
Alex
Hi Kristof,
becausemany users do not speak English. How can I do that? Is there an
xml file Ican edit?
Kristof Kelemen
sendan email to opendatakit...@googlegroups.com.
Groups"ODK Community" group.
send anemail to opendatakit...@googlegroups.com.
Groups "ODK Community" group.To unsubscribe from this group and stop receiving emails from it, send
an email to opendatakit...@googlegroups.com.For more options, visit https://groups.google.com/d/optout.
mitche...@gmail.com--
Hi Mitch,
I have thankfully found the source of the problem. As described here:
the Indonesian language folder needs to be renamed from 'values-id' to 'values-in' due to an idiosyncrasy of the Java language. I built ODK Collect with Eclipse ADT after changing the folder name to 'values-in' and the UI shows the Indonesian strings for me when the phone has Indonesian selected as the language.
Hope that helps. And a heads up for when you expand to Hebrew and Yiddish
-- James
