I have a finalized CSV file but I am not able to read it on excel. I use the function "import" and I specify to delimit with comma but I still get something incomprehensible (all the columns are mixed). Is it because the completed forms contain text with comma? What can I use to be able to read the data?
I would be very grateful if someone can help me with that.
My guess is that this is an issue with Excel, so as a quick fix, try LibreOffice or Numbers to see if they import the CSV any better.
If that doesn't work, then it'd help to know what version of Briefcase you are using and to get a copy of the CSV. I understand that your data might be too sensitive to share publicly, but if you can, please attach a CSV with the header row, one working row, and one row that is broken. If you can't share that data, it might be easier to try to recreate a few columns and a few rows so we can try to reproduce this.
