Trouble installing Aggregate with PostgreSQL
Hello Gabriel,
Any luck with you installing the ODK as im also facing the same issue. Did you get through installing it on postgre with tomcat. please let know that will ease my pain.
Thanks in advance.
Rahull
@usfreak13 What specific problems are you having? And on what OS and versions of Tomcat and PostgreSQL?
Based on your post at Problem Deploy OdkAggregate tomcat 9, Could not start application in context path [/ODKAggregate] - #3 by usfreak13 it seems like you are getting these error messages? If so, please see ODK Aggregate v2.00 - Possible Bug in Generated WAR File.
WARNING: Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanDefinitionStoreException: Invalid bean definition with name 'dataSource' defined in class path resource [odk-settings.xml]: Could not resolve placeholder 'jdbc.driverClassName' in string value "${jdbc.driverClassName}"; nested exception is java.lang.IllegalArgumentException: Could not resolve placeholder 'jdbc.driverClassName' in string value "${jdbc.driverClassName}"
Mar 01, 2019 2:09:54 AM org.springframework.web.context.ContextLoader initWebApplicationContext
SEVERE: Context initialization failed
        at org.springframework.beans.factory.config.PlaceholderConfigurerSupport.doProcessProperties(PlaceholderConfigurerSupport.java:223)
        at org.springframework.beans.factory.config.PropertyPlaceholderConfigurer.processProperties(PropertyPlaceholderConfigurer.java:222)
        at org.springframework.beans.factory.config.PropertyResourceConfigurer.postProcessBeanFactory(PropertyResourceConfigurer.java:86)
        at org.springframework.context.support.PostProcessorRegistrationDelegate.invokeBeanFactoryPostProcessors(PostProcessorRegistrationDelegate.java:281)
        at org.springframework.context.support.PostProcessorRegistrationDelegate.invokeBeanFactoryPostProcessors(PostProcessorRegistrationDelegate.java:161)
        at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:686)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:524)
        at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444)
        at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326)
        at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
        at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4817)
        at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5283)
        at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:754)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:730)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:734)
        at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:985)
        at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1857)
        at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
        at java.util.concurrent.FutureTask.run(Unknown Source)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
        at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.IllegalArgumentException: Could not resolve placeholder 'jdbc.driverClassName' in string value "${jdbc.driverClassName}"
        at org.springframework.util.PropertyPlaceholderHelper.parseStringValue(PropertyPlaceholderHelper.java:174)
        at org.springframework.util.PropertyPlaceholderHelper.replacePlaceholders(PropertyPlaceholderHelper.java:126)
        at org.springframework.beans.factory.config.PropertyPlaceholderConfigurer$PlaceholderResolvingStringValueResolver.resolveStringValue(PropertyPlaceholderConfigurer.java:258)
        at org.springframework.beans.factory.config.BeanDefinitionVisitor.resolveStringValue(BeanDefinitionVisitor.java:282)
        at org.springframework.beans.factory.config.BeanDefinitionVisitor.resolveValue(BeanDefinitionVisitor.java:204)
        at org.springframework.beans.factory.config.BeanDefinitionVisitor.visitPropertyValues(BeanDefinitionVisitor.java:141)
        at org.springframework.beans.factory.config.BeanDefinitionVisitor.visitBeanDefinition(BeanDefinitionVisitor.java:82)
        at org.springframework.beans.factory.config.PlaceholderConfigurerSupport.doProcessProperties(PlaceholderConfigurerSupport.java:220)
        ... 22 more
Mar 01, 2019 2:09:54 AM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance of class [org.springframework.web.context.ContextLoaderListener]
