Trouble trying to send finalised forms using Collect
Hello everyone,
I would appreciate some assistance troubleshooting an issue encountered by one of our en
umerators while using ODK Collect.
1. Description of the issue
We are using an XLSForm that implements ODK Entities (maybe this was needed so I am specifying this.). One of our enumerators is experiencing an error while trying to send finalised forms as in the image uploaded.
2. Troubleshooting steps already attempted
We have tried the following:
  • Restarting the tablet.
  • Connecting to a different Wi-Fi network.
  • Checking whether changing the internet connection resolves the issue.
Unfortunately, none of these steps has resolved the problem.
We are considering force-stopping ODK Collect, but we want to ensure that this will not put any locally stored drafts or unsent submissions at risk.
3. Form and Entity configuration
The XLSForm uses ODK Entities. We would particularly appreciate advice on whether this could be related to Entity List synchronization, entity creation or updates, or the way the form interacts with existing entities.
We are using odk central. Enumerator hasn't had any problems prior to this before. More than 1000+ submissions have already be done with the same form and other enumerators didn't have any error even when sendibg finalized forms immediately ornlater when accessing internet connection.
What are the most likely causes of this error?
Is force-stopping ODK Collect a safe troubleshooting step when there may be locally saved drafts or unsent submissions?
Or other possible steps to follow?
Thank you.
Hi John,
Do you have access to the server logs? It would be interesting to see if the enumerator's upload requests are reaching the server, and if there are any errors logged on the server side.
Alex
Sorry to hear about this, @johnmill99, it doesn't sound like an issue we've seen before.
Does your data collector have access to the "Ready to send" screen in Collect? If so, I would recommend trying to send one submission manually to see whether they get a more helpful error message.
Thank you everyone for your help. After contacting again with the enumerator and requesring more attempts and detailed screenshots from trying to send forms one by one we found that someone from the office (don't know how and why) accidentally had removed the enumerators access to the form. So it wasnt tablet or odk fault. Really sorry for making you worry for a bigger problem.
Thanks so much for following up, @johnmill99! Our big takeaway is that we really need to provide more explicit information about what happened when Collect reaches error states when submitting or downloading new form updates. We'll be working on this within the next few months and will share some of our proposed improvements for comment.
