I am scanning a barcode the name of the field is "barcode".
The output is a string in this form aaa|ssd fff vvv|a|err|1234567890|3356
I want to pass the individual regex matches into separate fields
This is what I have done so far:
In another field using calculate I have used regex(${barcode},('[^|]+')
the idea is to pull aaa into this field
then pull ssd fff vvv into another field -
I have tested the regex in regex101.com
I was expecting "true" as regex results in true or false
The next step would be to get the actual string match - not sure how as of yet
I would appreciate any ideas on this.
