Two datetimes is possible?
I want to take two times datetime information (first group datetime and second group datetime) in my survey. Is it possible?
If you want to know when specific questions are answered you can use lightweight timestamping.
You may also include as many manually entered dateTime type questions as you want.
Thanks for your reply, unfortunately this didn't work in xlsform in arcgis survey123 survey.
I added a trigger column to Excel, but it didn't work, the time comes automatically. There was no trigger for the variable named "Uyruk".
This forum and community is for the core ODK tools and specifications as listed on https://docs.getodk.org/ - for issues with Survey123 you will need to go through Esri Support.
