I would like to know how I can add a question which have two or more data types as their answer on XLSForms?
For example, for something as simple as entering the name of an individual, I want to give a single selection option for the part- 'Mr./Ms.' and then a text field for them to enter the rest of their name, what would I do?
You can use this example test_name.xlsx (8.7 KB)
This will still be asked as separate questions right? I was looking for a solution where it comes under a single question. Thank you though
If you need your data export to have the data in one cell, you could try to use a calculate
type question to combine the parts. Something like:
| type | name | label | appearance | calculation |
| begin group | name | | field-list | |
| select_one titles | title | Select title: | | |
| text | first | First name: | | |
| text | last | Last name: | | |
| end group | | | | |
| calculate | combined_name | | | concat(${title}," ",${first}," ",${last}) |
It is also easy to do this after export using formulas in a spreadsheet software such as Excel.
Thanks you two! Works for me
