Two relevant options put together
I have a question with three multiple choices (A. Normal Mobile Phone, B. SmartPhone C. I don't Own any phone). If a farmer selects either A or B or both A and B, the next five questions in the field list should appear. Is there a way to do this?
Collect v1.23
Aggregate v1.7.
Samsung Tab A (2016)
OS v5.1.1
have tried using relevant option "selected(${Do_you_own_a_mobile_or_smartphone},'smartphone')" and selected(${Do_you_own_a_mobile_or_smartphone},'normal_mobile_phone')
in the xlxs form. But seems only one option is working.
Is there a way to combine these two?? I hope so.
Field_Data_1.xlsx (12.0 KB)
https://odk.enke.to/preview?form=https://xlsform.opendatakit.org/downloads/i2l5tvnp/Field_Data_1.xml
Hi @Frimpongeben1
As you stated in your question, it sounds like you are interested in the condition
The other condition "both A and B" is already included in the previous one.
I suggest you modify your relevant condition to selected(${Do_you_own_a_mobile_or_smartphone},'smartphone') or selected(${Do_you_own_a_mobile_or_smartphone},'normal_mobile_phone')
Depending on the logic of the form (e.g. in case the question is mandatory) you should also be able to write it in the complementary way, i.e. not(selected(${Do_you_own_a_mobile_or_smartphone},'I_do_own_any_mobile_phone'))
Other suggestions are:
  1. Depending on the length and complexity of the form, as well as on the data analytics you plan to run, it might be advisable to code your answers (i.e. assigning a short name to options and leave the long text as label). The advantage is also in terms of size of the submission (kB)
  2. you might want to include a constraint to avoid incompatible options are selected (e.g. select C and A or B). You can perform this by including a constraint that exclude selection of more than one element and selection of option C.
  3. there seem to be some typos in the form, e.g. 'what_is_your_expeerience_with_network_quality_in_your_area': the spelling of experience
I hope this helps!
Andrea
