TypeError: Cannot read properties of null (reading 'dataset')
https://staging.enketo.getodk.org/preview?form=https%3A//staging.xlsform.getodk.org/downloads/417178dc8d2a44a8b46b94af9d61be0fmqd26xfp/GBS%20V3.xml
I get this error when loading this form, I don't understand why it appears, if I don't notice any error in the template. @Sadiq_Khoja you might help me with this mistake.
GBS V3.xlsx (360.8 KB)
Hi @Daniel_Zota,
The problem seems to be caused by the search appearance in combination with the (outer) repeat group with its repeat_count.. (@LN ?)
You may test it by temporarily
  • removing the repeat_count field (row 16).
  • renaming the column to XXappearance or by deleting all search appearances.
  • removing the repeat group temporarily (row 16 and 221).
It might only be a problem in the preview?
@Daniel_Zota Were you able to figure out this problem.
