Hi All,
I'm new to ODK Aggregate and I was trying to build a local instance from
the source. I'm somewhat familiar with Maven and POMs but
I'm encountering an error that makes no sense.
When I try and run an mvn install (or clean for that matter) on the main
POM with the following configuration (for MySQL)
aggregate-src
[ERROR] Failed to execute goal on project aggregate-mysql: Could not
resolve dependencies for project org.opendatakit:aggregate-mysql:war:1.0:
The following artifacts could not be resolved:
org.opendatakit:aggregate-src:jar:latest,
org.opendatakit:odk-mysql-it-settings:jar:latest,
com.google.gdata:gdata-core-1.0:jar:1.46.0,
com.google.gdata:gdata-client-1.0:jar:1.46.0,
com.google.gdata:gdata-client-meta-1.0:jar:1.46.0,
com.google.gdata:gdata-docs-3.0:jar:1.46.0,
com.google.gdata:gdata-docs-meta-3.0:jar:1.46.0,
com.google.gdata:gdata-maps-2.0:jar:1.46.0,
com.google.gdata:gdata-maps-meta-2.0:jar:1.46.0,
com.google.gdata:gdata-media-1.0:jar:1.46.0,
com.google.gdata:gdata-spreadsheet-3.0:jar:1.46.0,
com.google.gdata:gdata-spreadsheet-meta-3.0:jar:1.46.0,
com.google.gwt.google-apis:gwt-maps:jar:1.1.1-rc1,
com.google.gwt.google-apis:gwt-visualization:jar:1.1.1,
org.javarosa:javarosa-libraries:jar:latest,
org.opendatakit:odk-httpclient-gae:jar:1.0,
org.opendatakit:odk-tomcatutil:jar:1.0,
org.openid4java:openid4java-nodeps:jar:0.9.6.662.odk-SNAPSHOT,
org.springframework.security:spring-security-config:jar:3.1.0.odk-SNAPSHOT,
org.springframework.security:spring-security-core:jar:3.1.0.odk-SNAPSHOT,
org.springframework.security:spring-security-crypto:jar:3.1.0.odk-SNAPSHOT,
org.springframework.security:spring-security-openid:jar:3.1.0.odk-SNAPSHOT,
org.springframework.security:spring-security-web:jar:3.1.0.odk-SNAPSHOT:
Could not find artifact org.opendatakit:aggregate-src:jar:latest in central
(http://repo1.maven.org/maven2) -> [Help 1]
I have checked my local repository and all the files are there. I am
running Maven from within eclipse using the m2e plugin in Eclipse Helios.
Any input would be greatly appreciated.
Ok, After some work I was able to resolve it. A lot of the Artifacts had a
suffix in the form [artifactId].lastUpdated. The removal of the
'lastUpdated' suffix gets rid of this issue.
On Sunday, December 16, 2012 6:03:47 PM UTC+3, Kenneth Njendu wrote:
> Hi All,
> aggregate-src
> odk-mysql-settings
> odk-mysql-unit-settings
> aggregate-mysql
> mysql-unit-tests
> odk-tables-api
> I receive the following error;
> central (http://repo1.maven.org/maven2) -> [Help 1]
If you are new to ODK and ODK Aggregate, you should definitely first
set up Aggregate with the provided installers.
>> Hi All,
>> the source. I'm somewhat familiar with Maven and POMs but I'm encountering
>> aggregate-src
>> odk-mysql-settings
>> aggregate-mysql
>> mysql-unit-tests
>> odk-tables-api
You need to read the CONFIGURE.txt in the Aggregate source code directory.
That file will direct you, as part of the Maven environment setup, to the
src/main/libs/readme.txt which will explain how you should be registering
and obtaining these libraries.
On Sun, Dec 16, 2012 at 5:19 PM, Gaetano Borriello < gaetano@cs.washington.edu> wrote:
a
Hi All,
encountering
aggregate-src
Helios.
