Unable to get ODK Aggregate running on Ubuntu 20.04 with PostgreSQL 12
I'm struggling to have Aggregate to start/work on a Ubuntu 20.04 machine, with PostgreSQL 12.
On a different but similar machine with Ubuntu 18.04 that uses PostgreSQL 10 I have no issues.
Is a know issue?
This is the message in Catalina log:
01-Sep-2020 21:14:57.237 SEVERE [http-nio-8080-exec-25] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
01-Sep-2020 21:14:57.237 SEVERE [http-nio-8080-exec-25] org.apache.catalina.core.StandardContext.startInternal Context [/my_odk] startup failed due to previous errors
Thanks in advance.
I confirm it seems it is PostgreSQL 12: in created o aggregate instance on Ubuntu 20.04 pointing to a PostgreSQL 10 instance on another server, and works.
On Ubuntu Server 20.04 I also installed PostgreSQL 10 on port 5433, and surprisingly does not work with it, so there seems to be more at play.
Please I am currently facing the same issue. Were you able to resolve yours?
Server version:mysql 8.0.25-0ubuntu0.20.04.1 (Ubuntu)
please help, thanks
I have recently done a ODK aggregate on Ubuntu Server 20.04 with PostgreSQL 10 and it worked well.
Hi @manghig and @arazak584 please note that Aggregate has reached end-of-life and is no longer being updated. We suggest that you transition to Central when possible. More details in this post:
