From last few days download and export working correctly but now facing an error and data is downloading but not exporting to csv via briefcase .log file attached kindly support we are stucked here.
2022-02-09 15:31:23,851 [main] INFO org.javarosa.xform.parse.XFormParser - Reading XML and parsing with kXML2 finished in 206.638 ms
2022-02-09 15:31:23,940 [main] INFO org.javarosa.xform.parse.XFormParser - Consolidating text finished in 85.298 ms
2022-02-09 15:31:23,941 [main] INFO org.javarosa.xform.parse.XFormParser - Parsing form...
2022-02-09 15:31:23,941 [main] INFO org.javarosa.xform.parse.XFormParser - Title: "CLS_2021_CAPI_1_0_Rollout_KPCLS"
2022-02-09 15:31:23,943 [main] WARN org.javarosa.xform.parse.XFormParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [model] and will be ignored: [xforms-version]
Problem found at nodeset: /html/head/model
With element <model xforms-version="1.0.0"><submission base64RsaPublicKey="MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAy12jYQONRQVmuKBVxJDdr/vZ7FgnIW51PhXZOjB/QLVcxX8iPY8d92C4ElwdMNx94EoL4YklhLBHFKT4/au/FnCNPSna3uuWrM0L8JGsVvQRFMsCy0bAkvcn1dm6ngif5Vq7vk0bg2bPyNnqw5zcUubPVMIhOV6FQZqg83EYQ1oJ9mUeg1qZcgoB2dz63/9xEyc3Zn9lrbtCSJr7lNaVujdex6RPty1TCLiaL0GPRmwjvgmmTk6LtuHZNPFQhYpOzqm6vafKCa9jmwWhoWo9K/prfvwbMaMaKfTF3UvyHXO/nQzrqnz/w7M5T3XHpQe8uEqivXRY2EHUISOOyoxI4wIDAQAB"/>
2022-02-09 15:31:24,236 [main] WARN org.javarosa.xform.parse.XFormParser - XForm Parse Warning: Warning: 3 Unrecognized attributes found in Element [bind] and will be ignored: [location-max-age,location-min-interval,location-priority]
Problem found at nodeset: /html/head/model[@xforms-version=1.0.0]/bind
With element <bind nodeset="/data/meta/audit" location-max-age="120" location-min-interval="60" location-priority="balanced" type="binary"/>
2022-02-09 15:31:24,303 [main] WARN o.j.xform.parse.FormInstanceParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [instance] and will be ignored: [src]
Problem found at nodeset: /html/head/model[@xforms-version=1.0.0]/instance
With element <instance id="GeographyCCode" src="jr://file-csv/GeographyCCode.csv"/>
2022-02-09 15:31:24,304 [main] WARN o.j.xform.parse.FormInstanceParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [instance] and will be ignored: [src]
With element <instance id="FieldTeams" src="jr://file-csv/FieldTeams.csv"/>
2022-02-09 15:31:24,305 [main] WARN o.j.xform.parse.FormInstanceParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [instance] and will be ignored: [src]
With element <instance id="SelectedHH" src="jr://file-csv/SelectedHH.csv"/>
2022-02-09 15:31:24,306 [main] WARN o.j.xform.parse.FormInstanceParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [instance] and will be ignored: [src]
With element <instance id="ReplacedHH" src="jr://file-csv/ReplacedHH.csv"/>
2022-02-09 15:31:24,619 [main] INFO org.javarosa.xform.parse.XFormParser - Creating FormDef from parsed XML finished in 678.577 ms
2022-02-09 15:31:24,622 [main] INFO org.javarosa.xform.parse.XFormParser - Reading XML and parsing with kXML2 finished in 2.570 ms
2022-02-09 15:31:24,623 [main] INFO org.javarosa.xform.parse.XFormParser - Consolidating text finished in 0.126 ms
2022-02-09 15:31:24,623 [main] INFO org.javarosa.xform.parse.XFormParser - Parsing form...
2022-02-09 15:31:24,623 [main] INFO org.javarosa.xform.parse.XFormParser - Title: "Encrypted Form"
2022-02-09 15:31:24,623 [main] WARN org.javarosa.xform.parse.XFormParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [bind] and will be ignored: [length]
Problem found at nodeset: /html/head/model/bind
With element <bind nodeset="/data/base64EncryptedKey" type="string" length="2048"/>
2022-02-09 15:31:24,624 [main] WARN org.javarosa.xform.parse.XFormParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [bind] and will be ignored: [length]
With element <bind nodeset="/data/base64EncryptedElementSignature" type="string" length="2048"/>
2022-02-09 15:31:24,625 [main] INFO org.javarosa.xform.parse.XFormParser - Creating FormDef from parsed XML finished in 1.419 ms
2022-02-09 15:31:38,028 [main] ERROR org.opendatakit.briefcase.Launcher - Error
java.io.UncheckedIOException: java.nio.charset.MalformedInputException: Input length = 1
at java.io.BufferedReader$1.hasNext(Unknown Source)
at java.util.Iterator.forEachRemaining(Unknown Source)
at java.util.Spliterators$IteratorSpliterator.forEachRemaining(Unknown Source)
at java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
at java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.util.stream.ReferencePipeline.collect(Unknown Source)
at org.opendatakit.briefcase.export.CsvFieldMappers.aggregatedAuditFile(CsvFieldMappers.java:271)
at org.opendatakit.briefcase.export.CsvFieldMappers.lambda$null$2(CsvFieldMappers.java:70)
at java.util.Optional.map(Unknown Source)
at org.opendatakit.briefcase.export.CsvFieldMappers.lambda$static$3(CsvFieldMappers.java:70)
at org.opendatakit.briefcase.export.CsvFieldMapper.lambda$compose$0(CsvFieldMapper.java:66)
at org.opendatakit.briefcase.export.CsvFieldMapper.lambda$decorateOutput$1(CsvFieldMapper.java:76)
at org.opendatakit.briefcase.export.CsvFieldMappers.lambda$nonRepeatableGroup$18(CsvFieldMappers.java:290)
at java.util.stream.ReferencePipeline$7$1.accept(Unknown Source)
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(Unknown Source)
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(Unknown Source)
at java.util.stream.ReferencePipeline.forEach(Unknown Source)
at org.opendatakit.briefcase.export.CsvSubmissionMappers.lambda$main$2(CsvSubmissionMappers.java:63)
at org.opendatakit.briefcase.export.ExportToCsv.lambda$null$3(ExportToCsv.java:104)
at java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
at java.util.stream.ReferencePipeline$11$1.accept(Unknown Source)
at java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.util.stream.ForEachOps$ForEachTask.compute(Unknown Source)
at java.util.concurrent.CountedCompleter.exec(Unknown Source)
at java.util.concurrent.ForkJoinTask.doExec(Unknown Source)
at java.util.concurrent.ForkJoinPool$WorkQueue.runTask(Unknown Source)
at java.util.concurrent.ForkJoinPool.runWorker(Unknown Source)
at java.util.concurrent.ForkJoinWorkerThread.run(Unknown Source)
Caused by: java.nio.charset.MalformedInputException: Input length = 1
at java.nio.charset.CoderResult.throwException(Unknown Source)
at sun.nio.cs.StreamDecoder.implRead(Unknown Source)
at sun.nio.cs.StreamDecoder.read(Unknown Source)
at java.io.InputStreamReader.read(Unknown Source)
at java.io.BufferedReader.fill(Unknown Source)
at java.io.BufferedReader.readLine(Unknown Source)
... 55 common frames omitted
2022-02-09 15:31:39,051 [Thread-0] WARN io.sentry.connection.AsyncConnection - Graceful shutdown took too much time, forcing the shutdown.
2022-02-09 15:31:39,051 [Thread-0] WARN io.sentry.connection.AsyncConnection - 0 tasks failed to execute before shutdown.
2022-02-09 15:33:52,868 [main] INFO org.javarosa.xform.parse.XFormParser - Reading XML and parsing with kXML2 finished in 179.607 ms
2022-02-09 15:33:52,945 [main] INFO org.javarosa.xform.parse.XFormParser - Consolidating text finished in 73.141 ms
2022-02-09 15:33:52,945 [main] INFO org.javarosa.xform.parse.XFormParser - Parsing form...
2022-02-09 15:33:52,945 [main] INFO org.javarosa.xform.parse.XFormParser - Title: "CLS_2021_CAPI_1_0_Rollout_KPCLS"
2022-02-09 15:33:52,947 [main] WARN org.javarosa.xform.parse.XFormParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [model] and will be ignored: [xforms-version]
2022-02-09 15:33:53,172 [main] WARN org.javarosa.xform.parse.XFormParser - XForm Parse Warning: Warning: 3 Unrecognized attributes found in Element [bind] and will be ignored: [location-max-age,location-min-interval,location-priority]
2022-02-09 15:33:53,223 [main] WARN o.j.xform.parse.FormInstanceParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [instance] and will be ignored: [src]
2022-02-09 15:33:53,225 [main] WARN o.j.xform.parse.FormInstanceParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [instance] and will be ignored: [src]
2022-02-09 15:33:53,226 [main] WARN o.j.xform.parse.FormInstanceParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [instance] and will be ignored: [src]
2022-02-09 15:33:53,227 [main] WARN o.j.xform.parse.FormInstanceParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [instance] and will be ignored: [src]
2022-02-09 15:33:53,488 [main] INFO org.javarosa.xform.parse.XFormParser - Creating FormDef from parsed XML finished in 542.776 ms
2022-02-09 15:33:53,489 [main] INFO org.javarosa.xform.parse.XFormParser - Reading XML and parsing with kXML2 finished in 0.339 ms
2022-02-09 15:33:53,489 [main] INFO org.javarosa.xform.parse.XFormParser - Consolidating text finished in 0.082 ms
2022-02-09 15:33:53,489 [main] INFO org.javarosa.xform.parse.XFormParser - Parsing form...
2022-02-09 15:33:53,489 [main] INFO org.javarosa.xform.parse.XFormParser - Title: "Encrypted Form"
2022-02-09 15:33:53,489 [main] WARN org.javarosa.xform.parse.XFormParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [bind] and will be ignored: [length]
2022-02-09 15:33:53,490 [main] INFO org.javarosa.xform.parse.XFormParser - Creating FormDef from parsed XML finished in 0.870 ms
2022-02-09 15:34:27,844 [main] ERROR org.opendatakit.briefcase.Launcher - Error
at java.util.concurrent.ForkJoinPool$WorkQueue.execLocalTasks(Unknown Source)
... 56 common frames omitted
2022-02-09 15:34:28,933 [Thread-0] WARN io.sentry.connection.AsyncConnection - Graceful shutdown took too much time, forcing the shutdown.
2022-02-09 15:34:28,933 [Thread-0] WARN io.sentry.connection.AsyncConnection - 0 tasks failed to execute before shutdown.
