I am trying to create a form that will filter particular questions within a repeat based on responses given to two earlier questions in the same repeat.
The form I have created validates fine, but when I attempt to upload it, I get to ODK Aggregate, I get this:
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.lang.IllegalStateException
org.apache.catalina.connector.ResponseFacade.sendError(ResponseFacade.java:407)
javax.servlet.http.HttpServletResponseWrapper.sendError(HttpServletResponseWrapper.java:108)
org.springframework.security.web.context.SaveContextOnUpdateOrErrorResponseWrapper.sendError(SaveContextOnUpdateOrErrorResponseWrapper.java:81)
org.opendatakit.aggregate.servlet.FormUploadServlet.doPost(FormUploadServlet.java:342)
javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118)
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84)
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342)
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:103)
org.opendatakit.common.security.spring.SecurityContextHolderAwareAuthPreservingRequestFilter.doFilter(SecurityContextHolderAwareAuthPreservingRequestFilter.java:66)
org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
org.opendatakit.common.security.spring.OpenIDAuthenticationFilter.doFilter(OpenIDAuthenticationFilter.java:42)
org.opendatakit.common.security.spring.DigestAuthenticationFilter.doFilter(DigestAuthenticationFilter.java:42)
org.opendatakit.common.security.spring.OutOfBandUserFilter.doFilter(OutOfBandUserFilter.java:105)
org.opendatakit.common.security.spring.Oauth2ResourceFilter.doFilter(Oauth2ResourceFilter.java:351)
org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
org.springframework.security.web.access.channel.ChannelProcessingFilter.doFilter(ChannelProcessingFilter.java:144)
org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192)
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160)
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
It appears as though any reference to a relative path in a relevant column will produce the error. I for the life of me cannot figure out a way around this. I've attached a example of the form I am using.
Slimmed.xlsx (13.6 KB)
