Hi Community.
I recently uploaded the latest verision of the ODK aggregate onto the
AppEgngine. I was able to upload all the XML forms that were well.
After I tried exploring publishing options(did get to finish though) I
experienced that the ODK aggregate webpage would continuously reload. This
wa smy experience even in a different browser or computer. The page would
continuosly reload until somehow the google quota for the day would be
depleated.
This is a serious deployment issue that basically stalls my whole research
project.
Is there any one out there with this experience or know or the error/issue.
work around ?? PLEASE !!!
Hi there I had experienced that issue before, the solution worked for me is
first pull all the data with ODK briefcase for backup purposes.Second to
reinstall the last aggregate version with the same parameters ( appengine
instance name and username and password) , that way the data will be still
there , Mitch provided good support.
Good luck
2013/6/4 Sqripter
Hi Community.
depleated.
project.
error/issue. work around ?? PLEASE !!!
Jorge Durand Zurdo
*joduzu@gmail.com
Upgrade to Aggregate 1.3.1 -- it fixed an issue with the JSON publisher
that would case this problem.
If you are still having problems after upgrading to 1.3.1, if you are
running on Google AppEngine, invite me (mitchellsundt@gmail.com) as a
developer and I can take a look
http://code.google.com/p/opendatakit/wiki/AppEngineTroubleshooting
is first pull all the data with ODK briefcase for backup
purposes.Second to reinstall the last aggregate version with the same
parameters ( appengine instance name and username and password) , that way
the data will be still there , Mitch provided good support.
Good luck
2013/6/4 Sqripter qawori@gmail.com
Hi Community.
depleated.
research project.
Jorge Durand Zurdo
*joduzu@gmail.com
