I'm getting this when I try to start a new form:
I/PropertyManager( 8834): calling constructor
I/FormLoaderTask( 8834): Attempting to load STO Reconciliation.xml
from cached file:
/mnt/sdcard/odk/.cache/2cc29e46971c5a38f6447910d8d9186a.formdef
E/FileUtils( 8834): Cannot find STO Counting_2011-10-07_09-44-09.xml
W/System.err( 8834): java.io.FileNotFoundException:
/mnt/sdcard/odk/instances/STO Counting_2011-10-07_09-44-09/STO
Counting_2011-10-07_09-44-09.xml (No such file or directory)
W/System.err( 8834): at
org.apache.harmony.luni.platform.OSFileSystem.open(Native Method)
dalvik.system.BlockGuard$WrappedFileSystem.open(BlockGuard.java:232)
W/System.err( 8834): at java.io.FileInputStream.(FileInputStream.java:80)
org.odk.collect.android.utilities.FileUtils.getFileAsBytes(FileUtils.java:66)
org.odk.collect.android.tasks.FormLoaderTask.importData(FormLoaderTask.java:227)
org.odk.collect.android.tasks.FormLoaderTask.doInBackground(FormLoaderTask.java:180)
org.odk.collect.android.tasks.FormLoaderTask.doInBackground(FormLoaderTask.java:56)
W/System.err( 8834): at android.os.AsyncTask$2.call(AsyncTask.java:185)
java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:306)
java.util.concurrent.FutureTask.run(FutureTask.java:138)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1088)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:581)
W/System.err( 8834): at java.lang.Thread.run(Thread.java:1019)
I/ActivityManager( 98): Displayed
org.odk.collect.android/.activities.FormEntryActivity: +486ms
The weird thing is that it sometimes works the first time, but then
errors thereafter. The error shown on the phone is 'Sorry, Unable to
Parse Form'.
Any help would be appreciated. Thanks.
Update: It seems to have something to do with the slideout keyboard
crash fix that Carl posted. I reverted to a previous version and the
error went away.
> from cached file:
> Parse Form'.
I figured this out. The mInstance = null needs to go somewhere else. I
will post a bug and a patch when things calm down.
> error went away.
>> from cached file:
>> Parse Form'.
Hey Thomas,
It sounds like you haven't pulled all the changesets. The commit
immediately after the keyboard fix fixed the instance issue.
-Carl
error went away.
from cached file:
Parse Form'.
Oh I see. So is there like an RC2 tag now or something?
On 7 October 2011 15:48, Carl Hartung wrote:
> Hey Thomas,
> -Carl
>> > error went away.
>> >> from cached file:
>> >> Parse Form'.
nah, we forgot to tag. just use tip for now.
>> Hey Thomas,
>> -Carl
>>> > error went away.
>>> >> from cached file:
>>> >> Parse Form'.
