Use more than one filter option for choice filter in choice sheet
Hi All
I am using choice filter and would like choice filter to shows a certain option based on selection A or B.
For example, in the following choice sheet, I would like to show training option when someone selects Category finance or hr.
Its not an issue but a question on action/feature if possible.
I tired using comma between option/text like "finance,hr" but it did not work.
The above screenshot take from ODK Docs choice filter section.
Thanks in advance for helping.
Hi @Muhammad :smile:
You can try something like:
Choices Sheet
list_name name label category category2
job_titles training Training hr finance
Survey Sheet
type name label choice_filter
select_one job_titles job_title Job Title category=${job_category} or category2=${job_category}
Great day ahead! :smile:
Thanks @MinimalPotato for the answer
My issue is in some cases the category column will be like category1, category2, category3 and so on.
Plus I have two more attributes (State, Region, District) with similar issues, thus, if I apply this solution, I might have to deal with 9 columns.
Have a nice day.
Hmm, I guess you can even try something like this.. :thinking:
Choices Sheet
job_titles training Training hr,finance
Survey Sheet
select_one job_titles job_title Job Title contains(category, ${job_category})
I haven't tried it for myself, but i feel like it will work. Do let me know! :smile:
Yes, that would work! You just need to be very careful that the name of one category isn't contained in the name of another. For example, if you have hr_recruitment as a job category, it will match a contains filter for hr.
If you do need to have overlapping names, you can space-separate them like finance hr_recruitment and then use the selected function. If you have something like selected(category, ${job_category} and the value for ${job_category} is hr, it will NOT be identified as selected in the space-separated list above.
Ah! Thanks @LN ! :smile:
Never knew we could use "selected" over space separated sub-strings, it will definitely be a better way than using "contains" when dealing with overlapping names! :smile:
