That would be fantastic. I have windows mobile 6.1 hand helds I am using
for a project, but would like to introduce something lighter and more
simplistic....
On Fri, Feb 10, 2012 at 11:31 PM, Neil Penman neilp...@gmail.com wrote:
No problem. This version is still in test, I'm planning on releasing
it on the 17 February. So I''ll create a public Amazon image around about
then if thats ok. I'll also try and create some documentation on how to do
surveys that collect geometries.
Regards
Neil
On Sat, Feb 11, 2012 at 2:10 PM, Roxroy Bollers rkbo...@gmail.com wrote:
Hey Niel,
That is very impressive. I would appreciate the image of the amazon if
you have the time. Thanks for sharing.
R
On Fri, Feb 10, 2012 at 7:02 PM, Neil Penman neilp...@gmail.com wrote:
Yes. My test server is at http://thai. cloudtec.com.au
User: test
Pwd : test
There is an example survey on there using an area and also another
recording a path. I haven't tested using odkcollect for a while as I use a
variant of collect called fieldTask (available in market place).
Should work best with chrome. I can make an amazon image of the server
available if you are interested and the source code is available at Google
code project smap-suite.
Regards
On Feb 11, 2012 9:41 AM, "Roxroy Bollers" rkbo...@gmail.com wrote:
Niel that sounds doable. However do you by chance have a website to show
a demo.
On Friday, February 10, 2012, Neil Penman neilp...@gmail.com wrote:
I think you can achieve this without changing odkCollect. But you do
need custom server code, or an update to aggregate.
I create a repeating group and call it "geopolygon" or "geolinestring"
to record a path. Within the sub form I include a location question.
My server interprets these forms as composite questions and writes the
results to a postgis database as a geometry type. From there the geometries
can be analysed, exported as shape files or shown on a map.
Neil
On Feb 9, 2012 8:43 PM, "Jon Parsons" j.pa...@globalcanopy.org wrote:
Hi
I have just come back from Guyana where we are training 32 people
there to use ODK to record social and environmental data, most of it
based on a point location - but a new requirement has come up where
they are looking to record land use change in both its nature and
size.
We have be doing some initial work using a seperate app called
"distance and area measurment" which is doing what we want, but then
you have to export the data and copy into a GIS system to use and its
not possible for the user to add data about it.
So what I am wondering is if ODK has a component for linking to an
application within a collect form that can do this all together, so
data on the land use can be entered in a form and then the shape can
be drawn by the user by walking around the boundary and then the form
and shape data can be saved and published to fusion togehter for
visualisation.
Someone mentioned to me this tool might exist already does anyone
know, or if not is it on the list of things to develop in the future?
Jon
Sent from my iPhone
Play it forward and Have a good one!
"Like a camera I use the negative to develop..uDig"
"Success is the ability to go from one failure to another with no loss
of enthusiasm"
OutSourceRox
Roxroy K. Bollers
GIS and IT Consultant
tel. 592.685.2737
Follow Us On
Facebook
Google+
Web
of enthusiasm"
