Simplified examples are easier to fix, and then you can work on building
them out.
I've changed your choices sheet to have a column heading of
'feature_cat_filter' so that it is clearer what is going on.
Attached is a working implementation.
When you are working inside repeat groups, things get tricky.
In your example, you don't need to use indexed-repeat() because you are
referencing a value within your current repeat group. So you can use
relative addressing, e.g.,
../../g3/feature_cat
from within the feature_type field (instead of ${feature_cat})
../ gets up to the g4 group
../../ gets up to the parent of the g4 group (r1)
../../g3 navigates into the g3 group
../../g3/feature_cat references the value of the feature_cat field for
this iteration of the group.
i.e., relative addressing is a central concept to use and understand when
working within repeat groups.
HOWEVER, there is a gotcha in the evaluation logic whereby the filter
criteria is evaluating one level up (starting at g4 instead of at
'feature_type'). I believe this is a bug, but it has been out there so
long, we can't really fix it. So when we reference the feature_cat within
the filter criteria, we need to drop a leading ../ (using
../g3/feature_cat).
This is different than if you had tried to use relative referencing
within relevant, calculate or constraint conditions. In those, you would
need to write ../../g3/feature_cat
BUT, it still doesn't work.
The filter condition translates into the XML representation:
<itemset
nodeset="instance('feature_type_list')/root/item[feature_cat_filter
=../g3/feature_cat]">
And that is incorrect XML. The filter condition:
[feature_cat_filter =../g3/feature_cat]
evaluates all relative (..) addressing relative to:
instance('feature_type_ist')/root/item
i.e., ../g3/feature_cat is evaluated within the choices list, and not
within the form submission we are capturing. The solultion is to add
current()/ in front to reference to evaluate it within the current form
submission. That gives:
<itemset
=current()/../g3/feature_cat]">
which works.
Again, the corrected form is attached.
Enjoy!
Slimmed.xlsx (16.2 KB)
On Mon, Apr 6, 2015 at 4:59 PM, wrote:
Also note that this one hasn't even been altered to allow shared choices
for different answers. If I use this form in ODK collect, the option to
select any choice disappears.
