Using Central with Apache upstream proxy
Hello all, thanks for your work.
I configured odk central on my server on ports 8443 and 8888, side to Apache on ports 443 and 80.
All work, but not Enketo. The lunch is ok but the submit show error message 204.
Install odk with docker image with customSSL and custom ports 8443/8888.
I search in the logs docker but dont find any error.
#####Apache conf #####.
<VirtualHost *:443>
ServerName odk.exemple.com
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/odk.exemple.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/odk.exemple.com/privkey.pem
RewriteEngine On
RewriteCond %{SERVER_PORT} !^8443$
RewriteRule ^/(.*)$ https://%{SERVER_NAME}:8443/$1 [L,R=301]
<VirtualHost *:80>
RewriteEngine On
RewriteCond %{SERVER_PORT} !^8888$
#####.env conf :#####
DOMAIN=odk.exemple.com
SYSADMIN_EMAIL=odk@exemple.com
SSL_TYPE=customssl
HTTP_PORT=8888
HTTPS_PORT=8443
No one has any idea ?
Most of us are more familiar with using nginx than Apache for upstream proxying. Try Server configuration with reverse proxy returns timeout and proxy errors to see if you can find any hints to what working config looks like.
Thank's for your replay yanokwa !
I will follow your link and send feedback !
Regard
Hi !
news over here.
the problem was here:
RewriteEngine On
instead of using a rewrite, you have to use a proxy pass, like this
<VirtualHost *:443>
SSLProxyEngine On
SSLEngine on
ProxyPreserveHost On
ProxyPass / https://odk.exemple.com:8443/
ProxyPassReverse / https://odk.exemple.com:8443/
Have a nice day and thanks again to the team!
Hello RI RI
Would it be possible for you tos hare the complete Apache conf, the .env and the docker-compose.yml files , after changing any confidential IP and passwords please.
I have been trying to rouble shoot a similar issue behind nginx reverse proxy
Dr Vivek
Hello Dr Vivek,
Perhaps it would be more interesting if you shared your code. I could then compare it with mine and give you some guidance. Also, what exactly are your difficulties with this program on your side?
regard,
Thanks RiRi. I will share my configuration in morning tomorrow please. Really appreciate your offer of help
My issues is now resolved
Details at
Many Thanks Ri-Ri for your help
Best Wishes
Vivek
