I've tried the aggregate virtual machine and it works properly, Could i use
ODK collect with the aggregate vm ?
Yes. See line 42 of the read me that comes with the VM.
-- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.On Sat, Jan 2, 2016 at 3:38 AM, Gede Ananda Nartapradnyana 13.7635@stis.ac.id wrote:
ODK collect with the aggregate vm ?--
"ODK Developers" group.
The text said that i need port forwarding to use it onlinely, do you have
any clue or tutorial for it ?
Second, i tried to install ngrok to the virtual machine but the default
screen is the aggregate tty1 and I couldn't find the ubuntu homescreen
cause i can't login using the username in the readme.txt. Did i miss
something ? Thanks for always helping me
Gene,
Given your needs, I think your best option at this point is to install
Aggregate outside a VM or in the cloud (App Engine is the easiest).
-- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.On Sun, Jan 3, 2016 at 7:52 AM, Gede Ananda Nartapradnyana 13.7635@stis.ac.id wrote:
screen is the aggregate tty1 and I couldn't find the ubuntu homescreen cause
i can't login using the username in the readme.txt. Did i miss something ?
Thanks for always helping me--
