Hi all,
I'm trying to reformat a number value to be of the same length.
Here is an example of the expected output
1 = 00001
11 = 00011
111 = 00111
1111 = 01111
I've used the if command below but it doesn't give the output i expect
if((${number}=string-length(1)),concat(0000, ${number}), if((${number}=string-length(2)),concat(000, ${number}), if((${number}=string-length(3)),concat(00, ${number}),concat(0,${number}))))
How can I accomplish this?
Margaret
I think you can use regex expression, for your case try regex(.,'[0-9]{5}$')
- This should force the enumerators to add leading zeros. make sure the question type is text
and under appearance you have numbers
Hi @Megykaranja! Welcome to the forum.
For these kinds of form design questions, it's important to design iteratively. Build a very small two question form, and see if you can get it work for 1 = 00001
and 11 = 00011
. Once you have that working, incrementally build from there.
From a quick glance at your original post, I think the problems are:
- You aren't using string-length() correctly. According to the ODK XForm Spec, it should be
string-length(${number}) = 1
- You don't have quotes around the concat. I think it should be:
concat('0000', ${number})
Try those changes and go from there. Oh and in the future, please post support questions to Support. I've moved the thread.
Thanks so much Yaw.
It worked.
And # support noted.
