Using images with multiple-select from CSV
Hello,
I am trying to integrate the ODK feature of getting multiple-select options from a CSV file into a questionnaire we are designing. We are also thinking about adding images for the choices for this multiple-select. We aren't yet sure how well this will work, but would like to give it a try.
I found documentation for reading CSV choices from a file, which includes a note about adding an "image" column to be read from the csv file. However when using ODK Central, media files can only be uploaded corresponding to things referenced in the uploaded xlsform. Since the image names are stored in the csv file, no entry for these media files shows up there.
I'm wondering if there is a way to upload these image files?
I am facing similar issue with dynamic image attachment.
so far could not find any solution.
I found a way around this issue, I added a select_one question with "relevant" set to 0 (so that it doesn't show up in the questionnaire), and for the associated entry in the "choices" sheet, I added an entry for every image which could appear in the CSV file. Then it is possible to upload all of these images. It seems like this might work well enough for us.
@Prashant_K indeed, this does look very similar to your question at Upload media images via odk central that are not part of xlsform choice list/survey directly.
Central does not currently allow for uploading files that are not explicitly listed in the form. What you've come up with @mdg is the best approach I can think of.
@LN @mdg
Thanks you the for the reply.
The same work around I have implemented and it works smooth.
Except one very small issue that one unnecessary column in added to database.
I wanted to revisit this topic to see if it's affecting other people.
My use case:
  • I have large reference CSVs that contain a list of items and some data about them, plus media filenames
  • I want to show these media for reference (via a filtered select and image & big-image and tap to enlarge) or deliver them as dynamic images (ideally also with supressed 'take picture' & 'choose image' buttons) for annotation.
Currently in order to do this, I need to also include an unused choice list that includes all the filenames so that Central will request their upload. This means any changes to the reference file also requires a change to the unused choice list, and a form definition update. I may as well put the reference data as a choice list internally and keep updates to only one location, but this removes the modularity of the form design
Another update to this - beyond having to include a choice list with media filenames to enforce Central attachment upload currently.
If the question is a select_one/multiple_from_file using a CSV that has image and big-image columns in order to show media against the choices (and these have already been included in an internal choice list to force upload so the files are available), these are ignored and the display in Collect will not show the images, I can only make this work with an internal choice list.
For now I have to move questions with images back to internal choice lists, as well as keeping an unused choice list with media filenames when these are used as dynamic default images looked up from a CSV, but would prefer to avoid both these steps as keeping all these data in CSVs allows for a more modular form that's reusable with only updated CSVs.
(related thread on Enketo not handling image/big image and choice filters)
To bump this - the no show of images with a CSV also affects entity lists. So they can't show images against selects when you also use big-image
Currently the only workround is to query the entity list into the form and spill it to the internal choice list, which then needs definition updates when the entity list changes.
Either way the list of media need to be in the form to force their upload, so the above is also required anyway at the moment.
I couldn't find a Collect issue that seemed related to it, but also not sure if it's a Collect issue or pyxform etc. (Enketo can't show the images either and has other non ideal behaviour with selects with images and choice filters.)
Bonjour,
J'ai un problème un peu similaire a votre souci. J'ai un fichier csv qui contients les infos de quelques personnes. donc l'objectif c'est de les identifier avec les codes. j'ai utilisé la fonction pulldata.dès que je tape l'identifiant d'une personne les autres info apparaissent grace a l'option calculate. donc le gros souci c'est les photos qui n'apparaissent pas alors que ils sont listés dans le fichier csv. j'ai vu des astuces qui me parle de ${photo_file} dans la colonne media::image sur la ligne note çà n'a pas marché non plus. est-ce que quelqu'un a une solution par rapport çà?
