Hi community, the problem is when i put two or more households in the survey. As long as it is one, it does not happen. But when i put two or more, the indexed-repeat gives me a tipically error "You may need to use... bla bla bla". I use the indexed-repeat() function to show the name, surname and age of each member of each home, on the repeats labels of the modules.
ODK v1.12.2, Tablet Noblex 7' Android 6.0 Marshmallow
If you put two households, and two members per home (total of four members), you will see the error when the survey goes for the second repeat per home. You'll can write the information of the members of the second home, but when the first_module starts, the error shows.
I read a lot of documentation. xpath, writing the xml with the current() function, and much more. But i don know how to do that things. And although there are many open topics with the same motive, none of them was useful to me.
Yes, i leave an example file. Complete with two households and two members per home (4 total), and you will see the error in the second repeat per home.
test.xlsx (9.2 KB)
test.xml (5.4 KB)
