hi,
I have this table kish. The column contains the rank of the household and
the line number of household members. for example, if you enter 4 for the
rank of household and 3 as the number of members contained in this
household, SO ODK must return 1, the number which is at the intersection
of the column 4 and the line 3. Could you tell me how can i implement it
this in ODK.
Thanks a lot
I think what would be easiest is to put this table into an external
file and use the data preloading function described at
http://opendatakit.org/help/form-design/data-preloading/.
The key would be the number of members and the columns would be rank.
On Wed, Jul 9, 2014 at 5:04 PM, Legarraudien pagarraud1@gmail.com wrote:
hi,
household, SO ODK must return 1, the number which is at the intersection of
the column 4 and the line 3. Could you tell me how can i implement it this
in ODK.
Thanks a lot
Someone implementing a Kish grid pointed to this thread. They are using an entirely repeating pattern across rows, unlike the example shown above. For the example above, a lookup is necessary. For a regularly repeating pattern such as:
The following expression should get the desired result:
if(${rank} mod ${member_count} = 0, ${member_count}, ${rank} mod ${member_count})
This uses the mod operator which gives the remainder of division.
