Using multiple font sizes for answer choices in XLSForm
Good afternoon ODK!
I have been trying to use multiple font sizes for some of my answer choices akin to how questions can have hints, but I haven't been able to find a way to integrated that feature. I have tried adding markdown and have referred to the documentation available at the following link for styling prompts (https://xlsform.org/en/) but have had no success adjusting the font size.
Here's a screenshot of a Word document displaying what I am trying to accomplish
Thank you for your help.
You may also have a look here, please: https://docs.getodk.org/form-styling/.
Hi @jmax, it sounds like you are using Survey123? I don't know if it supports ODK's form styling and what, if any, additional styling it has. Your likely best bet is to contact ESRI.
Thanks for your answers, very much appreciate it!
@wroos Thanks, I'll explore to see if I can find a solution/workaround here.
@yanokwa Yes, I realize I forgot to mention it in my original post but it is for Survey123, and that makes total sense. I'll reach out to Esri support.
