I am new to the ODK development. I would like to know if it is possible to
use the ODK to develop forms for data entry on an android tablet rather
than a mobile phone. If the answer is yes, can we use the available tools
(like Excel) to do the form. Do you know of any links or websites for more
information
Thanks for the help in advance.
ODK works on most Android devices (including tablets). Yes, you can
use XLSForm to design the form. Go to http://opendatakit.org/use and
http://opendatakit.org/help for more information on how to use ODK.
-- Need ODK help? Go to http://nafundi.com for custom features, form design, implementation support, and user training for ODK.On Mon, Jun 24, 2013 at 9:01 AM, chanhinwing@gmail.com wrote:
use the ODK to develop forms for data entry on an android tablet rather than
a mobile phone. If the answer is yes, can we use the available tools (like
information
Thanks for the help in advance.--
"ODK Developers" group.
I have questions on using ODK for data collection. After the user submitted
the data to the backend, how do the user retrieve the data? Do I have to
write some SQL statement to retrieve the information?
Thanks for the help.
On Mon, Jun 24, 2013 at 1:49 PM, Yaw Anokwa wrote:ODK works on most Android devices (including tablets). Yes, you can
http://opendatakit.org/help for more information on how to use ODK.Yaw
to
than
(like
information
https://groups.google.com/d/topic/opendatakit-developers/wKZ9rOz6uto/unsubscribe
Hi Edward,
The best way to export the data is using CSV or ODK Briefcase. If you
want to stream the data to another web service (Google Fusion Tables,
JSON) you can do that as well (and pull the data from there).
You can also use the Briefcase API
(https://code.google.com/p/opendatakit/wiki/BriefcaseAggregateAPI) to
pull the data or retrieve the data with SQL (assuming a local
MySQL/PostgreSQL install) using
https://code.google.com/p/opendatakit/wiki/AggregateDatabaseStructure.
-- Need ODK services? http://nafundi.com provides form design, professional support, custom reporting, and software development for ODK.On Mon, Sep 16, 2013 at 7:56 AM, Edward Chan chanhinwing@gmail.com wrote:
Thanks for the help.On Mon, Jun 24, 2013 at 1:49 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
to
than
(like
information
Groups
an
https://groups.google.com/d/topic/opendatakit-developers/wKZ9rOz6uto/unsubscribe.
opendatakit-developers+unsubscribe@googlegroups.com.For more options, visit https://groups.google.com/groups/opt_out.
Mr. Yaw Anokwa or to whom it may concern,
I have two questions that I hope you can help me
with. 1) I noticed that I am not able to use 'goto label' on my Excel
spreadsheet where I tried publishing it on Formhub. I assume goto is not a
'type' that is supported. Am I correct or am I wrong? 2) What and how can I
do to get involve to create such a 'type'? I think the 'goto label' is a
very handy thing to have. I think OpenData kit has a lot of potential, but
it also has a lot of limitation.
Thank you for your help.
On Mon, Sep 16, 2013 at 6:32 PM, Yaw Anokwa wrote:Hi Edward,
JSON) you can do that as well (and pull the data from there).You can also use the Briefcase API
https://code.google.com/p/opendatakit/wiki/AggregateDatabaseStructure.Yaw
submitted
possible
to
rather
than
(like
information
Groups
an
To unsubscribe from this topic, visithttps://groups.google.com/d/topic/opendatakit-developers/wKZ9rOz6uto/unsubscribe
.To unsubscribe from this group and all its topics, send an email to
Hi Edward,
If you want to do branching, use the relevancy. XForms doesn't support
the goto concept so ODK Collect and the current generation of ODK
tools will likely never support it.
As far as ODK's limitations, code or cash contributions are always welcome.
-- Need ODK services? http://nafundi.com provides form design, professional support, custom reporting, and software development for ODK.On Mon, Oct 7, 2013 at 12:51 PM, Edward Chan chanhinwing@gmail.com wrote:
Thank you for your help.On Mon, Sep 16, 2013 at 6:32 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Hi Edward,
submitted
possible
to
rather
than
(like
information
Groups
send
an
To unsubscribe from this topic, visithttps://groups.google.com/d/topic/opendatakit-developers/wKZ9rOz6uto/unsubscribe.
Groups
an
'XLSForm' is a survey design tool for use with ODK Collect and the older
tools; it does not work with ODK Survey.
'XLSXConverter' is the survey design tool for the newer ODK Survey; *it
does not work with ODK Collect. *
'goto' does not exist in XLSForm; it is a feature of the newer
XLSXConverter and ODK Survey.
On Mon, Oct 7, 2013 at 10:43 AM, Yaw Anokwa wrote:Hi Edward,
tools will likely never support it.As far as ODK's limitations, code or cash contributions are always welcome.
me
a
can I
but
Hi Edward,
submitted
to
possible
to
rather
than
tools
(like
more
information
Groups
send
an
the
Groups
an
