I am working on a project what will use QR tags. When the user first opens the form, I wuld like them to scan the QR to prefill 3 or 4 data fields. An example would be, Location name, state, county, zip code. All of this would be embedded in the QR tag onsite. So when the user scans, it would put the results in the appropirate field. We have played with the Barcode function, but it does not make sense to have 4 Barcode lables and the user scan each one. I have searched fopr hours tring to find sample code but with no luck,
ODK does not currently provide this functionality and it's not easy to
get JavaROSA (the underlying library that ODK uses) to write data into
arbitrary prompts generically. ODK 2.0 will make this easier, but
those tools are still under development.
You might be able to scan the data into one barcode field, then have
calculated fields that extract that data using the substr() function.
This, however, is problematic because there is no index-of() function, so
each field you extract would have to be a certain fixed number of
characters wide.
On Sun, Jul 14, 2013 at 11:19 AM, Yaw Anokwa wrote:
Hi Brent,
I am interested on the same feature. It would be a great way to speed up
data collection.
I've checked, without success, the mailing list archive to see if this was
already implemented. As this is an older thread; I was keen to get back to
it and check if something was made or if there is a alternative solution.
Kind regards,
Gustavo
> characters wide.
> Mitch
> On Sun, Jul 14, 2013 at 11:19 AM, Yaw Anokwa <yan...@nafundi.com > wrote:
>> Hi Brent,
>> Your options are to file a feature request at
>> http://code.google.com/p/opendatakit and maybe someone in the
>> community will contribute the feature to the current ODK tools.
>> Alternatively, you can hire a developer at
>> http://opendatakit.org/help/help-for-hire to build this feature for
>> you.
>> Yaw
>> Need ODK services? Go to http://nafundi.com for form design, data
>> cleaning, custom reporting, and software development for ODK.
>> On Sat, Jul 13, 2013 at 8:45 AM, <brentpa...@gmail.com > wrote:
>> > Hello all,
>> > Thank you for any help.
>> > Brent
>> > Post: opend...@googlegroups.com
>> > Unsubscribe: opendatakit...@googlegroups.com
>> > Options: http://groups.google.com/group/opendatakit?hl=en
>> > You received this message because you are subscribed to the Google
>> Groups "ODK Community" group.
>> > To unsubscribe from this group and stop receiving emails from it, send
>> an email to opendatakit...@googlegroups.com .
>> > For more options, visit https://groups.google.com/groups/opt_out.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
Same caveats apply as before. The XZing barcode scanner can read QRCodes.
The JR library does not have an index-of function, so you need to have
fixed-width fields in your QRCode in order to split them out, or have the
QRCode have space-separated list of values and use selected-at() to extract
them -- in this case, the QRCode encodes: [first_part second_part]
On Mon, Aug 15, 2016 at 3:32 PM, wrote:
Hello everybody,
data collection.
Kind regards,
Gustavo
characters wide.
Thanks for the valuable input.
As I am new-user of ODK (and I have a background in agriculture), could
you please clarify if you the programming language is xml? If so, which are
the commands/codes supported by the JRosa library?
Should I make these changes using Notepad++ (code editor) or should I
use/can the online build platform.
Thank you very much and, please, excuse my ignorance.
Gustavo
> On Mon, Aug 15, 2016 at 3:32 PM, <gustavo...@utas.edu.au > wrote:
>> Hello everybody,
>> data collection.
>> was already implemented. As this is an older thread; I was keen to get back
>> to it and check if something was made or if there is a alternative solution.
>> Kind regards,
>> Gustavo
>>> so each field you extract would have to be a certain fixed number of
>>> characters wide.
>>> Mitch
>>>> Hi Brent,
>>>> you.
>>>> Yaw
>>>> On Sat, Jul 13, 2013 at 8:45 AM, wrote:
>>>> > Hello all,
>>>> > Brent
>>>> send an email to opendatakit...@googlegroups.com.
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
Build is easier than XLSForm which is easier that XML. I'd recommend
you try XLSForm and try to build a basic barcode form.
As I am new-user of ODK (and I have a background in agriculture), could you
please clarify if you the programming language is xml? If so, which are the
Gustavo
data collection.
Kind regards,
Gustavo
characters wide.
but with no luck,
You are definitely right about it. Additionally, sorry for the absence of
information:
As Brent, I am trying to use a QR Code to speed up the process of
manually filling information throughout the whole form. If there is no
barcode (or the user is keen no to use) then he could do it manually;
I thought about subset of a string; thus, something like:
On Tuesday, August 16, 2016 at 6:53:45 PM UTC+10, Yaw Anokwa wrote:
> Hi Gustavo,
> Yaw
> On Tue, Aug 16, 2016 at 3:28 AM, <gustavo...@utas.edu.au > wrote:
> > Hi Mitch,
> you
> the
> > Gustavo
> QRCodes.
> the
> extract
> >>> Hello everybody,
> up
> >>> data collection.
> back
> solution.
> >>> Kind regards,
> >>> Gustavo
> function,
> >>>> characters wide.
> >>>> Mitch
> >>>>> Hi Brent,
> to
> into
> >>>>> you.
> >>>>> Yaw
> >>>>> > Hello all,
> first
> data
> code. All of
> scans, it
> with the
> lables and
> sample code
> >>>>> > but with no luck,
> >>>>> > Brent
> send
> >>>> Mitch Sundt
> >>>> Software Engineer
> >>>> mitche...@gmail.com
> Groups
> an
> >> Mitch Sundt
> >> Software Engineer
> >> mitche...@gmail.com
> Groups
> an
No need to be sorry. We all have to start from somewhere!
It's hard to figure out why the form did not work without a demo form.
So, build a three question demo form. One question with barcode and
two questions with the substrings you want to have. See if that works,
if it doesn't then send that small form out and the community can take
a look.
information:
As Brent, I am trying to use a QR Code to speed up the process of manually
filling information throughout the whole form. If there is no barcode (or
Hi Gustavo,
in-field training, and software development for ODK. Go to https://nafundi.com to get started.
you
the
Gustavo
QRCodes.
the
extract
up
data collection.
back
solution.
Kind regards,
Gustavo
function,
characters wide.
to
into
first
data
code. All of
scans, it
with the
lables and
sample code
but with no luck,
Groups
an
Groups
an
