H Guy,
I Want to enter a code like that 12345_12. The five first numbers could any
integer and this sign "_" and the two last numbers could be any integer.
Here is my constraint. and it doesn't work. Can any one help me?
regex(.,'^([0-9]+-[0-9]{5,2}$')
regex(.,'{5}_[0-9]{2}$')
http://regexone.com has tutorials for regex.
On Wed, Jul 9, 2014 at 8:10 PM, Legarraudien pagarraud1@gmail.com wrote:
H Guy,
I Want to enter a code like that 12345_12. The five first numbers could any integer and this sign "_" and the two last numbers could be any integer. Here is my constraint. and it doesn't work. Can any one help me?
Hi Yaw,
I Can't Type the "_" and i have a constraint message "the aswer is not
correct".
2014-07-09 20:14 GMT-07:00 Yaw Anokwa :
H Guy,
My regex work if i change "" with "-". How can i select this symbol ""
2014-07-10 5:03 GMT-07:00 Pierre Anthony Garraud :
Hi Yaw,
correct".
2014-07-09 20:14 GMT-07:00 Yaw Anokwa yanokwa@nafundi.com:
H Guy,
Pierre,
Depends on the keyboard. On mine, it's shift + the key between )/0 and
+/=. The character is called an underscore (un souligné, un tiret
bas). You can also copy and paste it into your form.
On Thu, Jul 10, 2014 at 6:51 AM, Pierre Anthony Garraud pagarraud1@gmail.com wrote:
2014-07-10 5:03 GMT-07:00 Pierre Anthony Garraud pagarraud1@gmail.com:
Hi Yaw,
correct".
H Guy,
Thanks a lot, i'll try it
2014-07-10 7:31 GMT-07:00 Yaw Anokwa :
Pierre,
Hi Yaw,
correct".
H Guy,
could
help me?
send
Groups
an
