I note that the documentation for the new SSO capability in 2023.4 states:
Enabling SSO currently disables API access. This means you won't be able to use PowerBI, Excel, ruODK, pyODK or other such tools to directly access data on your server. You'll need to export CSVs instead.
Is this likely to be a long term constraint or will it be relaxed any time soon?
May thanks
