problem: I am getting the following errors when trying to validate my XLS form:
Error: ODK Validate Errors:
XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [bind] and will be ignored: [requiredMsg] Location:
Problem found at nodeset: /html/head/model/bind
With element <bind requiredMsg="jr:itext('${estudo_numero}:jr:requiredMsg')" nodeset="${estudo_numero}" required="true()" type="int"/>
With element <bind requiredMsg="jr:itext('${date}:jr:requiredMsg')" nodeset="${date}" required="true()" type="dateTime"/>
With element <bind requiredMsg="jr:itext('${Inquiridor}:jr:requiredMsg')" nodeset="${Inquiridor}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${A1}:jr:requiredMsg')" nodeset="${A1}" required="true()" type="int"/>
With element <bind requiredMsg="jr:itext('${A2}:jr:requiredMsg')" nodeset="${A2}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${A3}:jr:requiredMsg')" nodeset="${A3}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${A4}:jr:requiredMsg')" nodeset="${A4}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${A4_other}:jr:requiredMsg')" nodeset="${A4_other}" relevant=" ${A4} = 96" required="true()" type="string"/>
With element <bind requiredMsg="jr:itext('${A5}:jr:requiredMsg')" nodeset="${A5}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${A5_other}:jr:requiredMsg')" nodeset="${A5_other}" relevant=" ${A5} = 96" required="true()" type="string"/>
With element <bind requiredMsg="jr:itext('${A6}:jr:requiredMsg')" nodeset="${A6}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${A6_other}:jr:requiredMsg')" nodeset="${A6_other}" relevant=" ${A6} = 96" required="true()" type="string"/>
With element <bind requiredMsg="jr:itext('${A7}:jr:requiredMsg')" nodeset="${A7}" required="true()" type="string"/>
With element <bind requiredMsg="jr:itext('${A8}:jr:requiredMsg')" nodeset="${A8}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${A8_other}:jr:requiredMsg')" nodeset="${A8_other}" relevant=" ${A8} = 96" required="true()" type="string"/>
With element <bind requiredMsg="jr:itext('${A9}:jr:requiredMsg')" nodeset="${A9}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${A10}:jr:requiredMsg')" nodeset="${A10}" relevant=" ${A9} = 1" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${Sexualmente_ativo}:jr:requiredMsg')" nodeset="${Sexualmente_ativo}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${B15}:jr:requiredMsg')" nodeset="${B15}" relevant=" ${Sexualmente_ativo} = 2" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${B15_other}:jr:requiredMsg')" nodeset="${B15_other}" relevant=" ${B15} = 96" required="true()" type="string"/>
With element <bind requiredMsg="jr:itext('${B1}:jr:requiredMsg')" nodeset="${B1}" required="true()" type="int"/>
With element <bind requiredMsg="jr:itext('${B2}:jr:requiredMsg')" nodeset="${B2}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${B3}:jr:requiredMsg')" nodeset="${B3}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${B5}:jr:requiredMsg')" nodeset="${B5}" relevant=" ${B3} = 2" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${B5_other}:jr:requiredMsg')" nodeset="${B5_other}" relevant=" ${B5} = 96" required="true()" type="string"/>
With element <bind requiredMsg="jr:itext('${B4}:jr:requiredMsg')" nodeset="${B4}" relevant=" ${B3} = 1" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${B4_other}:jr:requiredMsg')" nodeset="${B4_other}" relevant=" ${B4} = 96" required="true()" type="string"/>
With element <bind requiredMsg="jr:itext('${B6}:jr:requiredMsg')" nodeset="${B6}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${B7_other}:jr:requiredMsg')" nodeset="${B7_other}" relevant=" ${B7} = 96" required="true()" type="string"/>
With element <bind requiredMsg="jr:itext('${B8}:jr:requiredMsg')" nodeset="${B8}" required="true()" type="int"/>
With element <bind requiredMsg="jr:itext('${B9}:jr:requiredMsg')" nodeset="${B9}" required="true()" type="select1"/>
With element <bind requiredMsg="jr:itext('${B10}:jr:requiredMsg')" nodeset="${B10}" relevant=" ${B9} = 1" required="true()" type="select1"/>
XForm Parse Error: Encountered a problem with display condition for node [${B11}] at line: ${B9} ,{B10} = 1, Couldn't understand the expression starting at this point: ...ente_ativo/B9 ,?{B10} = 1
org.javarosa.xform.parse.XFormParseException: Encountered a problem with display condition for node [${B11}] at line: ${B9} ,{B10} = 1, Couldn't understand the expression starting at this point: ...ente_ativo/B9 ,?{B10} = 1
XForm is invalid. See above for the errors.
Result: Invalid
What ODK tool and version are you using? And on what device and operating system version? I am using the validate feature on the ODK website from my macbook pro computer.
I have tried editing my XLS form but i do not really understand the error message so I am not sure how to edit my XLS form appropriately.
