I am conducting a study where data collectors have to choose 1 out of three choices depending on the time frame reached by the study.Can anyone please help on how do I make a first choice invalid after a period of 3 months and then only second choice active after 6 months and only a third choice active for selection after 9 months. Or any other approach any can have..
For example (a question on the form):
Please choose which test are you currently conducting:
a. Pre Test
b. Mid Test
c. Post Test
From there I want a data collector in first place to conduct a pre test, after 3 months he/she to only be able to select Mid test, and after 6 months I want only a "post test" selection to be active for selection
either constraint or choice_filter or relevant depending on your survey flow
Does the single survey file contain different sets of questions for each of the tests (pre, mid, and post)? And is the set of questions based on the time since a set date in the past?
Hellow @danbjoseph, Thank you, I am glad to be here too!
A single survey file will have the same questions for pre, mid and post test, I have tried choice_filter and relevant but data collectors keep accidentally selecting the wrong choice
eg: mistakenly select post test at times when pre or mid test is being conducted
Is this something you can automatically calculate in the background?
What if you have a second question to make them acknowledge the answer they input?
