I've noticed that the GeoPoint widget is tremendously slow in obtaining
a position. In the very same places, other apps such as Maps and "GPS
Status" obtain the position almost immediately.
Does anybody know what those apps do differently so that I can modify
the geopoint widget and make it as fast as those apps in obtaining a
position?
m.
Most apps use cell phone towers for geolocation. ODK Collect relies on a
full GPS satellite lock.
Since ODK Collect was designed to operate out of cell tower connectivity in
remote parts of the world, the GPS locking was the initial and only choice.
Not sure what is needed to support both. Seems like this would be a choice
with each form and/or geopoint question?
Any changes should probably be discussed with the wider javarosa community,
as this is likely a change to the XForms parsing.
On Wed, Jul 11, 2012 at 4:49 AM, Matteo Sisti Sette < matteosistisette@gmail.com> wrote:
I've noticed that the GeoPoint widget is tremendously slow in obtaining a
position. In the very same places, other apps such as Maps and "GPS Status"
Does anybody know what those apps do differently so that I can modify the
geopoint widget and make it as fast as those apps in obtaining a position?
m.
From version 1.1.7+ Collect actually uses both GPS and cell/wifi for
localization (it'll use either or both depending on what has been enabled
in the phone's preferences by the user). Likely the reason it seems slow
is that it requires a certain accuracy before automatically recording the
location, regardless of the method used to get location.
in remote parts of the world, the GPS locking was the initial and only
choice.
choice with each form and/or geopoint question?
community, as this is likely a change to the XForms parsing.
m.
Those settings are set from the phone's Settings menu, Location & Security
screen, at the top.
Thanks Carl!
choice.
position?
m.
