Wish to display dates which more than the current date and those less than the current date as "past"
I am trying to calculate dates that a woman should go for antenatal care. However I wish to only show those dates which are still due and not those that have already passed (using the current date). I have tried to firstly used the calculation this formula format-date(date(decimal-date-time(${last_menstrual})+84), "%d-%m-%Y") to calculate the first ANC date(similarly for all 8 visits) based on the Last menstrual date. I then used this if statement: if(${first_anc_visit} < format-date(date(today()),"%d-%m-%Y"),"past",${first_anc_visit}) so that if the date is less than today's date, it should display "past" otherwise it should display the actual date. The problem is it simply just return dates for all the visits. Sometimes it only gives a single visit as past which is not correct. Is there anywhere am making it wrong or where i can improve the formula.
ODK
I have tried to change the dates to be in the same format
I am uploading the snippet code of the form
anc_visit_problem.xlsx (16.8 KB)
Hi @newtonnyapwere
I think you compare dates in a wrong way you need to convert them using decimal-date-time function first. Here is your form with fixes: anc_visit_problem (1).xlsx (9.5 KB)
Thanks https://forum.getodk.org/u/Grzesiek2010 it worked! I am now good to go.
