The high problem that am trying to solve is restoration of the wetland
Odk can help me to prepare questionnares and making of a budget
https://www.thomaswetland.com
Welcome to the ODK forum, @Thomas_Wanjala ! We're glad you're here. When you get a chance, please introduce yourself on this forum thread. Thanks for adding your profile picture, it helps build community!
The ODK software can certainly be used to create questionnaires. The docs have a
section on getting started - the easiest way is to pay for ODK Cloud but you can also self-host the software on your own infrastructure.
For learning XLSForm there's a tutorial to help you with your first form.
