On Tue, Nov 20, 2012 at 4:19 AM, Isaac Barfi wrote:
> Hi Guys,
> Is there any documentation or an API for the Xform parsing engine as used by the Javarosa libraries?
> I am currently developing a .NET custom (Aggregate) backend and would be grateful if such a document was available.
> PS: I have checked and implemented all the API's as shown on the OpenRosaAPI entry but there is none for Xform parsing and processing.
> Kind regards,
Before you roll your own, you should talk to Martijn, ( "Martijn van de
Rijdt" martijn@aidwebsolutions.com, ), as he has a port of javarosa
implemented in Javascript.
Also search the group for others that have rolled their own servers; you
might be able to save yourself some time (though I have not heard of any
.NET implementations).
On Tue, Nov 20, 2012 at 9:10 AM, Yaw Anokwa wrote:
